From Oracle
Data can be exported from an Oracle database.
| Type | Parameter | Description | Example Value |
| Basic parameters | Use SQL Statement | Whether you can use SQL statements to export data from a relational database | No |
| SQL Statement | If you have set Use SQL Statement to Yes, enter an SQL statement. CDM exports data based on the SQL statement. NOTE:
| select id,name from sqoop.user; | |
| Schema/Table Space | Name of the schema or tablespace from which data will be extracted. This parameter is displayed when Use SQL Statement is set to No. Click the icon next to the text box to go to the page for selecting a schema or directly enter a schema or tablespace. If the desired schema or tablespace is not displayed, check whether the login account has the permissions required to query metadata. This parameter can be set to a regular expression to export all databases that meet the rule. | SCHEMA_E | |
| Table Name | Name of the table from which data will be extracted. This parameter is displayed when Use SQL Statement is set to No. Click the icon next to the text box to go to the page for selecting the table or directly enter a table name. If the desired table is not displayed, check whether the table exists or whether the login account has the permission to query metadata. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time. This parameter can be set to a regular expression to export all databases that meet the rule. For example, if Table Name is set to user_[0-9]{1,2}, tables from user_0 to user_9 and from user_00 to user_99 are matched. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | table | |
| Advanced attributes | Where Clause | Where clause used to specify the data extraction range. This parameter is displayed when Use SQL Statement is set to No. If this parameter is not set, the entire table is extracted. You can set a date macro variable to extract data generated on a specific date. For details, see Incremental Migration of Relational Databases. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | DS='${dateformat(yyyy-MM-dd,-1,DAY)}' |
| Retain One Decimal Place for Date Values | Whether to retain one decimal place for date values. | No | |
| Extract by Partition | This parameter is displayed when Extract by Partition is set to No. It indicates that when data is exported from an Oracle database, data can be extracted from each partition in the partitioned table. If this function is enabled, you can configure Table Partition to specify specific Oracle table partitions from which data is extracted.
| No | |
| Partition Extraction Column | This parameter is displayed when Extract by Partition is set to No, indicating a field used to split data during data extraction. CDM splits a job into multiple tasks based on this field and executes the tasks concurrently. Fields with data distributed evenly are used, such as the sequential number field. Click the icon next to the text box to go to the page for selecting a field or directly enter a field. NOTE: The following types of partition columns are supported: TINYINT, SMALLINT, INTEGER, BIGINT, REAL, FLOAT, DOUBLE, NUMERIC, DECIMAL, BIT, BOOLEAN, DATE, TIME, and TIMESTAMP. It is recommended that the partition column have an index. | id | |
| Null for Partition Column | Whether the partition field can contain null values. This parameter is displayed when Extract by Partition is set to No. During concurrent extraction, if the partition column does not contain null, set this parameter to No to improve performance. If you are not sure whether the partition column contains null, set this parameter to Yes to avoid data loss. | Yes |
