Help Center/ DataArts Studio/ User Guide/ DataArts Migration (Offline Jobs)/ Creating an Offline Processing Migration Job
Updated on 2026-01-28 GMT+08:00
An offline processing migration job can be executed to perform a series of operations on data. Before configuring an offline processing migration job, create a job.
This function is in OBT (or restricted use). To use this function, submit a service ticket.
Notes and Constraints
Offline processing migration jobs are not supported in enterprise mode.
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the left navigation pane of DataArts Factory, choose Development > Develop Job.
  4. Create a migration job using either of the following methods:
    Method 1: On the Develop Job page, click Create Data Migration Job.
    Figure 1 Creating a migration job (method 1)
    Method 2: In the directory list, right-click a directory and select Create Data Migration Job.
    Figure 2 Creating a migration job (method 2)
  5. In the displayed Create Data Migration Job dialog box, configure job parameters. Table 1 describes the job parameters.
    Table 1 Job parameters
    Job Name
    Name of the job. The name must contain 1 to 128 characters, including only letters, numbers, hyphens (-), underscores (_), and periods (.).
    Job Type
    Job type. Select Offline processing.
    Select Directory
    Directory to which the job belongs. The root directory is selected by default.
    Job Description
    Description of the job
  6. Click OK.
Configuring Basic Job Information
After you configure the owner and priority for a job, you can search for the job by the owner and priority. The procedure is as follows:
Click the Basic Info tab on the right of the canvas to expand the configuration page and configure the job parameters listed in Table 2.
Figure 3 Configuring basic job information
Table 2 Basic job information
Owner
An owner configured during job creation is automatically matched. This parameter value can be modified.
Executor
This parameter is available when Scheduling Identities is set to Yes.
User that executes the job. When you enter an executor, the job is executed by the executor. If the executor is left unspecified, the job is executed by the user who submitted the job for startup.
You can configure execution users only after you apply for the whitelist membership. To enable it, contact customer service or technical support.
Job Agency
After an agency is configured, the job interacts with other services as an agency during job execution.
Priority
Priority configured during job creation is automatically matched. This parameter value can be modified.
Execution Timeout
Timeout of the job instance. If this parameter is set to 0 or is not set, this parameter does not take effect. If the notification function is enabled for the job and the execution time of the job instance exceeds the preset value, the system sends a specified notification.
Exclude Waiting Time from Instance Timeout Duration
Whether to exclude the wait time from the instance execution timeout duration
  • If you select this option, the time to wait before an instance starts running is excluded from the timeout duration. You can modify this setting on the Default Configuration page.
  • If you do not select this option, the time to wait before an instance starts running is included in the timeout duration.
Custom Parameter
Set the name and value of the parameter.
Job Tag
Configure job tags to manage jobs by category.
Click Add to add a tag to the job. You can also select a tag configured in Managing Job Tags.
Node Status Polling Interval (s)
How often the system checks completeness of the node task. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again.
Retry upon Failure
You can select Retry 3 times or Never. Never is recommended.
You are advised to configure automatic retry only for file migration jobs or database migration jobs with Import to Staging Table enabled to avoid repeated data writes caused by automatic retry.
If you want to set parameters in DataArts Studio DataArts Factory to schedule the CDM migration job, do not configure this parameter. Instead, set parameter Retry upon Failure for the CDM node in DataArts Factory.
Policy for Handling Subsequent Nodes If the Current node Fails
Policy for handling subsequent nodes if the current node fails
  • End the current job execution plan: Execution of the current job will stop, and the job instance status will become Failed. If the job is scheduled periodically, subsequent periodic scheduling will run properly.
  • Ignore the failure and set the job execution result to success: The failure of the current node will be ignored. The job instance status will become Failure ignored. If the job is scheduled periodically, subsequent periodic scheduling will run properly.
Configuring Job Parameters
Job parameters can be globally used in any node in jobs. The procedure is as follows:
Click Parameter Setup on the right of the editor and set the parameters described in Table 3.
Table 3 Job parameter setup
Functions
Variables
Add
Click Add and enter the variable parameter name and parameter value in the text boxes.
  • Parameter
    Only letters, numbers, hyphens, and underscores (_) are allowed.
  • Parameter Value
    • The string type of parameter value is a character string, for example, str1.
    • The numeric type of parameter value is a number or operation expression.
After the parameter is configured, it is referenced in the format of ${parameter name} in the job.
Edit Parameter Expression
Click next to the parameter value text box. In the displayed dialog box, edit the parameter expression. For more expressions, see Expression Overview.
Modifying a Job
Change the parameter name or value in the corresponding text boxes.
Mask
If the parameter value is a key, click to mask the value for security purposes.
Delete
Click next to the parameter name and value text boxes to delete the job parameter.
Constant Parameter
Add
Click Add and enter the constant parameter name and parameter value in the text boxes.
  • Parameter
  • Parameter Value
Modifying a Job
Modify the parameter name and parameter value in text boxes and save the modifications.
Delete
