Elasticsearch Link Parameters
Elasticsearch links can be used to connect to Elasticsearch services in third-party clouds and local data centers and on Elastic Cloud Servers (ECSs).
- The Elasticsearch connector only supports Elasticsearch clusters in non-security mode.
- Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 lists the parameters for an Elasticsearch link.
Parameter | Description | Example Value |
Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | es_link |
Elasticsearch Server List | IP addresses or domain names (including the port numbers) of one or more Elasticsearch servers. The format is ip:port. Use semicolons (;) to separate multiple IP addresses or domain names. | 192.168.0.1:9200;192.168.0.2:9200 |
