Elasticsearch Connection Parameters (Internal Test)
| Parameter | Mandatory | Description |
| Data Connection Type | Yes | Elasticsearch is selected by default and cannot be changed. |
| Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
| Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
| Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
| Applicable Modules | Yes | Select the modules for which this connection is available. The connection can be used in the selected modules. NOTE:
| Network Connectivity Configuration | ||
| Elasticsearch Server List | Yes | One or more server lists (server domain name/IP address:server port) separated by semicolons (;). Example: 192.168.0.1:9200;192.168.0.2:9200 |
| KMS encryption key | Yes | KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key. NOTE:
| Agent | Yes | DataArts Studio cannot directly connect to non-fully managed services. An agent is required for DataArts Studio to communicate with non-fully managed services. A CDM cluster can function as an agent. If no CDM cluster is available, create one by referring to Creating a CDM Cluster. |
| Data Migration Configuration | ||
| Security Mode Authentication | Yes | Whether to enable security mode authentication. |
| HTTPS Access | Yes | This parameter is displayed when security mode authentication is enabled. Whether to enable HTTPS access. Accessing a cluster through HTTPS improves security but deteriorates cluster performance. |
| Connection timeout | No | Connection timeout duration, in milliseconds. The default value is 10000. |
| Socket timeout | No | Timeout duration, in milliseconds. The default value is 60000. |
| Enable GZIP compression | No | Whether to enable GZIP compression. Set http.compression to true on the Elasticsearch node. |
| Data Source Authentication and Other Function Configuration | ||
| Username | Yes | Username for connecting to Elasticsearch |
| Password | Yes | Password for connecting to Elasticsearch |
