Apache HDFS Connection Parameters (Internal Test)
| Parameter | Mandatory | Description |
| Data Connection Type | Yes | The value is fixed at Apache HDFS. |
| Name | Yes | Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-). |
| Description | No | A description which can help identify the data connection more easily. It can contain a maximum of 100 characters. |
| Tag | No | Attribute of the data connection to create. Tags make management easier. NOTE: The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters. |
| Applicable Modules | Yes | Select the modules for which this connection is available. The connection can be used in the selected modules. NOTE:
| Basic and Network Connectivity Configuration | ||
| Use Cluster Config | Yes | Select a cluster configuration that has been created. You can use the cluster configuration to simplify parameter settings for the Hadoop connection. The function is disabled by default. |
| URI | Yes | This parameter is displayed when Use Cluster Config is enabled. NameNode URI. You can enter hdfs://IP address of the NameNode instance:8020. |
| IP and Host Name Mapping | No | This parameter is displayed when Use Cluster Config is enabled. This parameter is used only when Run Mode is set to EMBEDDED or STANDALONE. If the HDFS configuration file uses the host name, configure the mapping between the IP address and host name. Separate the IP addresses and host names by spaces and mappings by semicolons (;), carriage returns, or line feeds. |
| KMS encryption key | Yes | KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key. NOTE:
| Agent | Yes | DataArts Studio cannot directly connect to non-fully managed services. An agent is required for DataArts Studio to communicate with non-fully managed services. A CDM cluster can function as an agent. If no CDM cluster is available, create one by referring to Creating a CDM Cluster. |
| Data Migration Configuration | ||
| Config Path | Yes | This parameter is displayed when Use Cluster Config is enabled. It specifies the OBS path for storing the cluster configuration file. |
| keytab File Path | Yes | This parameter is displayed when Authentication Method is set to KERBEROS. Select the OBS path where the keytab file is stored. |
| Principal Name | Yes | This parameter is displayed when Authentication Method is set to KERBEROS. Enter the Kerberos authentication username. For a Kerberos cluster, you need to upload the corresponding keytab file. |
| Properties | No | This parameter is available when CDM Enable is enabled. This parameter is optional. You can click Add to add custom attributes. |
| Data Source Authentication and Other Function Configuration | ||
| Authentication Method | Yes | Authentication method used for accessing the cluster:
| Process Type | Yes | Run mode of the HDFS link. The options are as follows:
