On this page
Show all
Oracle Connection Parameters
Updated on 2025-02-18 GMT+08:00
Table 1 Oracle connection
Mandatory
Data Connection Type
Yes
ORACLE is selected by default and cannot be changed.
Name
Yes
Name of the data connection to create. Data connection names can contain a maximum of 100 characters. They can contain only letters, digits, underscores (_), and hyphens (-).
Tag
No
Attribute of the data connection to create. Tags make management easier.
The tag name can contain only letters, digits, and underscores (_) and cannot start with an underscore (_) or contain more than 100 characters.
Applicable Modules
Yes
Select the modules for which this connection is available.
  • When the data migration job feature is enabled, you can select the DataArts Migration module. Then you can select this data connection when creating a data migration job in DataArts Factory.
  • You can use offline processing migration jobs only after apply for the whitelist membership. To use this feature, contact customer service or technical support.
Basic and Network Connectivity Configuration
IP Address or Domain Name
Yes
Address for accessing the database to be connected. You can enter a public/private IP address or a domain name.
Port
Yes
The port of the database to connect.
KMS Key
Yes
KMS key used to encrypt and decrypt data source authentication information. Select a default or custom key.
When you use KMS for encryption through DataArts Studio or KPS for the first time, the default key dlf/default or kps/default is automatically generated. For more information about default keys, see What Is a Default Master Key?.
Agent
Yes
DataArts Studio cannot be directly connected to non-fully managed services. A CDM cluster can provide an agent for DataArts Studio to communicate with non-fully-managed services. Therefore, you need to select a CDM cluster when creating an Oracle data connection. If no CDM cluster is available, create one first by referring to Creating a CDM Cluster.
As a network proxy, the CDM cluster must be able to communicate with Oracle.
Data Source Authentication and Other Function Configuration
Username
Yes
Username used for accessing the database This account must have the permissions required to read and write data tables and metadata.
If you have the CONNECT permission (read-only permission) and are trying to create a connection, a message is displayed indicating that the table or schema does not exist. In this case, perform the following operations to grant permissions:
  1. Log in to the Oracle node as user root.
  2. Run the following command to switch to user oracle:
    su oracle
  3. Run the following command to log in to the database:
    sqlplus /nolog
  4. Run the following command to log in as user sys:
    connect sys as sysdba;
    Enter the password of user sys.
  5. Run the following SQL statement to grant permissions:
    GRANT SELECT ON GV_$INSTANCE to xxx;
    In the preceding command, xxx indicates the name of the user to which the permissions will be granted.
Password
Yes
Password of the username
Connection Type
Yes
Select a connection type.
  • SID
    SID indicates the ID of the Oracle database instance. One instance corresponds to only one database, but one database can correspond to multiple instances.
  • Service Name
    It was introduced since Oracle8i and indicates the external service name of the Oracle database.
SID
Yes
This parameter is mandatory when Connection type is set to SID.
Service Name
Yes
This parameter is mandatory when Connection type is set to Service Name.
This parameter was introduced since Oracle8i and indicates the external service name of the Oracle database.
