Downloading a File from JupyterLab to a Local Path
Files created in JupyterLab can be downloaded to a local path. For details about how to upload files to JupyterLab, see Uploading Files to JupyterLab.
- If a file is no larger than 100 MB, directly download it from JupyterLab. For details, see Downloading a File No Larger Than 100 MB to a Local Path.
- If a file is larger than 100 MB, transfer it from JupyterLab to OBS and then download it from OBS to a local path. For details, see Downloading a File Larger Than 100 MB to a Local Path.
In the JupyterLab file list, right-click the file to be downloaded and select Download from the shortcut menu.
The file will be downloaded to your browser's downloads folder.
Upload a file larger than 100 MB from a notebook instance to OBS and then download the file from OBS to a local path. The procedure is as follows:
- Open the Python runtime environment.
    As shown in the following figure, click python-3.7.10 in the Notebook area on the Launcher page. The following figure shows an example environment. Figure 2 Opening the Python runtime environment
- Call the ModelArts SDK to upload the target file from the notebook instance to OBS.
    - Call the ModelArts SDK for uploading a file to OBS.
      Sample code: Upload file1.txt in the notebook instance to OBS bucket obs://bucket-name/dir1/. All the bucket name, folder name, and file name are customizable. from modelarts.session import Session session = Session() session.obs.upload_file(src_local_file='/home/ma-user/work/file1.txt', dst_obs_dir='obs://bucket-name/dir1/')
- Call the ModelArts SDK for uploading a folder to OBS.
      Sample code: Upload /work/ in the notebook instance to obs://bucket-name/dir1/work/ of bucket-name. The bucket name and folder name are customizable. from modelarts.session import Session session = Session() session.obs.upload_dir(src_local_dir='/home/ma-user/work/', dst_obs_dir='obs://bucket-name/dir1/')
- Use OBS or ModelArts SDK to download the file from OBS to the local path.
    - Method 1: Use OBS to download the file.
      Download obs_file.txt from OBS to the local path. If you have a large amount of data, use OBS Browser+ to download data or folders. For details about how to download OBS files, see Downloading a File.
- Method 2: Downloading the files using the ModelArts SDKs
      Download files from OBS to a local path. For details, see Downloading a File from OBS. The sample code is as follows:from modelarts.session import Session # Hard-coded or plaintext AK/SK is risky. For security, encrypt your AK/SK and store them in the configuration file or environment variables. # In this example, the AK/SK is stored in environment variables for identity authentication. Before running this example, set environment variables HUAWEICLOUD_SDK_AK and HUAWEICLOUD_SDK_SK. __AK = os.environ["HUAWEICLOUD_SDK_AK"] __SK = os.environ["HUAWEICLOUD_SDK_SK"] # Decrypt the information if it is encrypted. session = Session(access_key=__AK,secret_key=__SK, project_id='***', region_name='***') session.download_data(bucket_path="/bucket_name/obs_file.txt",path="/home/user/obs_file.txt")
