Checking the Cluster Version and Permissions
Unified permission governance has requirements on the data connection agent, data source version, and user permissions. Before using it, you need to check and prepare related configurations based on Table 1.
DLI permission management involves only Authorizing dlg_agency and does not involve cluster version and permissions check.
Checklist
| Check Item | Mandatory | Check Content | Configuration Guide |
| Data connection agent version | Mandatory for MRS/DWS permission management | The CDM cluster version is 2.10.0.300 or later. | Log in to the CDM console and click Cluster Management. In the cluster list, locate the required cluster and click the cluster name. On the Basic Information page, view the cluster version. If the version is not the required one, create another CDM cluster of the latest version or contact customer service or technical support. |
| Ranger component configuration | Mandatory for MRS permission management | LDAP user synchronization is enabled for the Ranger component of an MRS non-security cluster. | In a non-security MRS cluster, the Ranger component synchronizes Unix users by default, but does not synchronize users, user groups, or roles on Manager. Therefore, you need to switch the user synchronization policy. For details, see Configuring the Ranger Component. |
| Ranger connection user permission | The user for the connection has the admin permission of the Ranger component. | The user for the Ranger connection must have the admin permission of the Ranger component. For details, see Preparing a Ranger Admin User. | |
| guest_agent version of the DWS cluster | Mandatory for DWS permission management | The guest_agent version of the DWS cluster is 8.2.1, or later than 8.2.1 and earlier than 9.0.0. | You can view the guest agent version of the DWS cluster using a developer debugging tool. For details, see Viewing the Guest Agent Version of a DWS Cluster. |
| DWS connection user permissions |
| DLI agency permissions | Mandatory for DLI permission management | A DLI agency has permissions to access cloud services. | For details, see Configuring DLI Agency Permissions. |
- Log in to the DWS console, choose Clusters, and locate a cluster.
- Press F12 to open the developer debugging tool and click the Network tab. Figure 1 Network
- Click the name of the cluster to go to the Basic Information page. On the Network tab page, locate and click the long string starting with clusters?type=xxxxxx. In the right pane, click Preview and search for the guest_agent_version field, whose value is the guest_agent version of the DWS cluster. Figure 2 Locating the guest_agent_version field
- If the version is not your required one, contact the customer service or technical support of DWS.
In a non-security MRS cluster, the Ranger component synchronizes Unix users by default, but does not synchronize users, user groups, or roles on FusionInsight Manager. Therefore, you need to switch the user synchronization policy. The procedure is as follows:
By default, the Ranger component of an MRS security cluster synchronizes LDAP users. No additional operation is required. If the default configuration is changed, you can change the user synchronization policy by referring to this section.
- Log in to MRS Manager as user admin.
- Choose Cluster > Services > Ranger and click Configurations and then Basic Configurations. Search for the ranger.usersync.sync.source parameter and select ldap. If this parameter is not found, search for the ranger.usersync.config.expandor parameter and set its name to ranger.usersync.sync.source and its value to ldap.
By default, this parameter is unavailable for MRS clusters of old versions (for example, MRS 3.1.0). You can contact the customer service or technical support of MRS for support.
Figure 3 Configuring the ranger.usersync.sync.source parameter
Figure 4 Configuring the ranger.usersync.config.expandor parameter
- After the parameter is set, click Save in the upper left corner and then OK in the dialog box to save the configuration.
- After the configuration is saved, switch to the Instances tab page, select the UserSync instance that has expired, click More, and select Instance Rolling Restart to make the configuration take effect. Figure 5 Performing a rolling instance restart
The user for the Ranger connection must have the admin permission of the Ranger component. The procedure is as follows:
- Choose . On the page displayed, click Create to add a dedicated human-machine user as the Kerberos authentication user. Select user groups superGroup and hive for the user, and assign the Manager_administrator role to the user.
- Log in to MRS Manager as the new user and change the initial password.
- On the Manager page, choose Cluster > Services > Ranger. On the Ranger overview page, click RangerAdmin to go to the Ranger WebUI. Figure 6 Accessing the Ranger WebUI
- Log out of the current account and use the Ranger administrator account to log in again. For a common cluster, the admin account for the Manager page can be used as the Ranger administrator account. For a security cluster, rangeradmin is the Ranger administrator account. For details about the default password of rangeradmin, see User Account List. Figure 7 Logging out of the current account
- Change the role of the new user from Ranger to Admin. Find the name of the new user in Settings > Users/Groups/Roles > Users.
If the new user is not found on Ranger, wait for about five minutes until Ranger automatically synchronizes the MRS cluster role.
Figure 8 Searching for the username
- Click the username to go to the details page, change the user role to Admin, and click Save. Figure 9 Changing the user role
