Dynamic Watermarks
Dynamic watermarking means dynamically inserting watermarks into the result sets returned by data query and access requests. This section describes how to enable dynamic watermarking for DataArts Factory so that data watermarks can be dynamically inserted during the dump or download of sensitive data in DataArts Factory.
After data development dynamic watermarking is enabled for DataArts Security and a dynamic watermarking policy is created, when a user group or role specified in the policy dumps or downloads sensitive data in DataArts Factory, DataArts Factory injects an invisible watermark into the sensitive data to protect it from being disclosed.
- Register with and log in to the management console.
- Hover the cursor on the username in the upper right corner and select My Credentials from the drop-down list.
- On the API Credentials page, obtain the account name, account ID, IAM username, and IAM user ID, and obtain the project and its ID from the project list.
Note that dynamic watermarking policies configured for a DataArts Studio instance are visible to and take effect for all the workspaces of the instance.
An MRS Hive, MRS Spark, or DWS connection has been created.
- Only the DAYU Administrator, Tenant Administrator, or data security administrator can enable or disable dynamic watermarking for DataArts Factory. The workspace administrator can create dynamic watermarking policies. Other common users do not have permission to perform these operations.
- Dynamic watermarking policies are only available for MRS Hive, MRS Spark, and DWS data sources.
- Adding, deleting, or modifying a dynamic watermarking policy takes about five minutes to take effect.
- A watermark will be inserted only when more than 500 rows of data are to be dumped or downloaded. If there are less than 500 rows of data, source tracing will be impossible even if a watermark is inserted.
Creating a Dynamic Watermarking Policy
- Log in to the DataArts Studio console.
For details, see Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Security.
- In the navigation pane on the left, choose Privacy Protection > Dynamic Watermarking. Figure 1 Accessing the Dynamic Watermarking page
- Click
to enable dynamic watermarking for DataArts Factory. Click Create and set the parameters listed in Table 1. Figure 2 Setting parameters for the dynamic watermarking policy
The following table lists the parameters.Table 1 Policy parameters Parameter
*Policy Name
Unique identifier of the dynamic watermarking policy. It must be unique in a DataArts Studio instance.
To facilitate policy management, you are advised to include the object to be watermarked and the watermark to be added in the name.
User Group/Role
User, user group, or role in the current workspace members. When a specified object queries or exports sensitive data from DataArts Factory, the system adds a dynamic watermark to the sensitive data to protect the sensitive data from being disclosed.
*Data Source Type
Select MRS Hive, MRS Spark, or DWS from the drop-down list.
*Data Connection
If no data connection is available, create one by referring to Creating a DataArts Studio Data Connection.
*Cluster Name
You do not need to set this parameter. The data source cluster in the data connection is automatically selected.
*Database
Databases where the sensitive data is stored.
*Data Table
Tables where the sensitive data is stored. You need to set one of the following table selection modes:
- After setting all required parameters, click OK.
Related Operations
- Extracting a watermark: After obtaining the CSV data file containing a dynamic watermark from DataArts Factory, trace the watermark by referring to Extracting a Watermark.
- Editing a policy: On the Dynamic Watermarking page, locate a policy and click Edit in the Operation column.
- Setting the policy status: A watermarking policy is enabled by default. If the watermarking policy is disabled, it does not take effect.
To change the status of a watermarking policy, click
or
to enable or disable the policy. - Deleting policies: On the Dynamic Watermarking page, locate a policy and click Delete in the Operation column. To delete multiple policies, select them and click Delete above the list.
The deletion operation cannot be undone. Exercise caution when performing this operation.
- Viewing policy details: On the Dynamic Watermarking page, locate a policy and click its name to view its details. Figure 3 Viewing policy details
