Updated on 2025-02-18 GMT+08:00
Configuring Resource Permissions
This section describes how to create resource permission policies for Ranger to control access to MRS resources and reduce data security risks for your enterprise.
  • A Ranger connection has been created in Management Center, and a correct RangerAdmin service IP address and Ranger service port have been set for the connection (see MRS Ranger Connection Parameters for details).
    When you test the Ranger connection in Management Center, the Ranger service IP address and port will not be verified, and no error will be reported even if they are incorrect. You are advised to check them manually.
  • Ranger authentication has been enabled for the corresponding MRS cluster. In security mode, Ranger authentication is enabled by default. In common mode, Ranger authentication is disabled by default. For details, see Enabling Ranger Authentication.
  • Resource permission policies depend on the Ranger authentication of MRS clusters. Currently, only permissions on MRS resources can be controlled.
  • A permission policy takes effect about 1 minute after being configured.
MRS Components that Support Access Control and the Permission List
Ranger can be used to integrate components in MRS clusters of version 3.0.0 or a later version to enable fine-grained access permission control for components. Table 1 lists the supported components and describes related permissions. For details, see Configuring Component Permission Policies.
Table 1 Supported components and permissions
Component
Permission
HDFS
HDFS file permissions:
  • Read: the permission required for read
  • Write: the permission required for write
  • Execute: the permission required for executing a job
Hive
Hive database, data table, and column permissions:
  • Select: the permission required for query
  • Update: the permission required for update
  • Create: the permission required for creation
  • Drop: the permission required for dropping
  • Alter: the permission required for alteration
  • All: the permissions required for all operations
  • Temporary UDF Admin: the permission required for managing a temporary UDF
Yarn
Yarn queue permissions:
  • submit-app: the permission required for submitting a queue
  • admin-queue: the permission required for managing a queue
HBase
HBase column and column family permissions:
  • Admin: the permission required by an administrator
Kafka
Kafka topic permissions:
  • Publish: the permission required for production
  • Consume: the permission required for consumption
  • Configure: the permission required for expanding the capacity of a topic
  • Describe: the permission required for query
  • Create: the permission required for creating a topic
  • Delete: the permission required for deleting a topic
  • Describe Configs: the permission required for querying configurations
  • Alter Configs: the permission required for modifying configurations
Storm
Storm topology permissions:
  • Submit Topology: the permission required for submitting a topology
  • File Upload: the permission required for uploading a file
  • File Download: the permission required for downloading a file
  • Kill Topology: the permission required for deleting a topology
  • Rebalance: the permission required for rebalance
  • Activate: the permission required for activation
  • Deactivate: the permission required for deactivation
  • Get Topology Conf: the permission required for getting the configurations of a topology
  • Get Topology: the permission required for getting a topology
  • Get User Topology: the permission required for getting a user topology
  • Get Topology Info: the permission required for getting the information of a topology
  • Upload New Credential: the permission required for uploading a new credential
Creating an HDFS Permission Policy
  1. On the DataArts Studio console, locate a workspace and click DataArts Security.
  2. Choose Access Permission Management > Resource Permission Settings from the left navigation bar.
    If error message "cluster [mrs_3x_autotest_do_not_del] get service failed. due to [null response from cdm:[404 NOT FOUND]]." is displayed, check whether the RangerAdmin service IP address and Ranger service port of the Ranger connection are correct in Management Center by referring to MRS Ranger Connection Parameters.
    Figure 1 Resource Permission Settings page
  3. Click Configure to the right of hacluster under the HDFS component, and click Create in the upper part of the page displayed.
    Figure 2 Creating a permission policy
  4. Set the parameters and click OK.
    Figure 3 Assigning a permission policy
    Table 2 Parameters for configuring an HDFS permission policy
    Policy Type
    The policy type is automatically generated based on the selected service component. Policy Type can be set to Access, Mask, and Row-level Filter. Mask and Row-level Filter are specific to Hive.
    Policy Status
    If Policy Status is Enabled, the permission policy takes effect immediately. If Policy Status is Disabled, the permission policy does not take effect after being created. Policy Status is set to Enabled by default.
    Overwrite
    If Overwrite is set to Enabled, the new policy takes effect and the old policy does not take effect. Overwrite is set to Enabled by default.
    When you need to create a temporary access policy, enable Overwrite and set Validity Period as required. In this way, even if the temporary access policy expires, the original permission policy still takes effect.
    Audit Log
    If Audit Log is set to Enabled, logs are recorded. The log content includes the client access time, client IP address, client user, and resource operation result.
    Policy Name
    Policy name is mandatory. A policy name can include only letters, numbers, underscores (_), and hyphens (-). Up to 50 characters are allowed.
    A description of the policy. Up to 256 characters are allowed.
    Topology
    HDFS path for access permission control.
    Recursion
    If the function is enabled, the resource path is in recursive mode. If the function is disabled, the resource path is in non-recursive mode. Policy Status is set to Enabled by default.
    Validity Period
    You can set the effective time and expiration time of a policy. You can configure multiple time ranges.
    Allowed
    Users and user groups that are allowed to access the resources.
    • Username: MRS user.
    • Role: MRS role.
    • Group: MRS user groups.
    • Permission: the permission required by users who are allowed to access the system. Permission and Username can be left blank or not left blank at the same time. For details on service permissions, see Table 1.
    • Granted: If Granted is selected, management permissions are assigned to appropriate users and groups. Delegated administrators can update and delete policies and create sub-policies based on the original policies.
    Exceptions
    If you select Exceptions for Allowed, users who are not allowed to access the system are added to the user group that is allowed to access the system.
    If you select Exceptions for blocked, users who are allowed to access the system are added to the user group that is blocked from the system.
    Block all other accesses
    If you select Block all other accesses, only specified users or user groups are allowed to access the system.
    Blocked
    Blocked is displayed when Block all other accesses is not selected. Users and user groups that are not allowed to access the system can be specified in the Blocked area.
    • Role: MRS role.
    • Permission: the permission required by users who are not allowed to access the system. Permission and Username can be left blank or not left blank at the same time. For details on service permissions, see Table 1.
Creating a Hive Access Permission Policy
    Figure 4 Resource Permission Settings page
  3. Click Configure to the right of the Hive component, and click Create in the upper part of the page displayed.
    Figure 5 Creating a permission policy
    Figure 6 Configuring a Hive policy
    The following table lists the parameters of a Hive permission policy.
    Table 3 Parameters of a Hive permission policy
    Policy Type
    Policy Status
    Overwrite
    To create a temporary access policy, enable Overwrite and set Validity Period as required. In this way, even if the temporary access policy expires, the original permission policy still takes effect.
    Audit Log
    Policy Name
    database
    The database parameter is mandatory. You can set the database whose permissions need to be controlled. Fuzzy search is supported.
    table
    The table parameter is mandatory. You can set the table whose permissions need to be controlled. Fuzzy search is supported.
    Column
    The Column parameter is mandatory. You can set the column whose permissions need to be controlled. Fuzzy search is supported.
    Validity Period
    Allowed
    • Role: MRS role.
    Exceptions
    Blocked
    • Role: MRS role.
Creating a Hive Masking Permission Policy
    Figure 7 Resource Permission Settings page
  3. Click Configure to the right of the Hive component, and click Create in the upper part of the Mask tab page.
    Figure 8 Creating a permission policy
    Figure 9 Configuring a Hive policy
    Table 4 Parameters of a Hive permission policy
    Policy Type
    Policy Status
    Overwrite
    Audit Log
    Policy Name
    Database
    The Database parameter is mandatory. You can set the database whose permissions need to be controlled. Fuzzy search is supported.
    Data Table
    The Data Table parameter is mandatory. You can set the table whose permissions need to be controlled. Fuzzy search is supported.
    Column
    Validity Period
    Mask
    The masking mode for users or user groups to access data.
    • Role: MRS role.
    • Mask Mode: Columns that require permission control in a Hive table are masked based on the value of this parameter.
Creating a Hive Row-Level Filter Permission Policy
    Figure 10 Resource Permission Settings page
  3. Click Configure to the right of the Hive component, and click Create in the upper part of the Row-level Filter tab page.
    Figure 11 Creating a Hive row-level filter policy
    Figure 12 Configuring a Hive policy
    Table 5 Parameters of a Hive permission policy
    Policy Type
    Policy Status
    Overwrite
    Audit Log
    Policy Name
    Database
    Data Table
    Column
    Validity Period
    Row-level Filter
    • Role: MRS role.
    • Row-level Filter: Filter by field content. The parameter format is as follows: Field=Value. Example: state=1.
Creating an HBase Permission Policy
    Figure 13 Resource Permission Settings page
  3. Click Configure to the right of the HBase component, and click Create in the upper part of the page displayed.
    Figure 14 Creating an HBase permission policy
    Figure 15 Configuring an HBase policy
    Table 6 Parameters of an HBase permission policy
    Policy Type
    Policy Status
    Overwrite
    Audit Log
    Policy Name
    Data Table
    Column
    Column Family
    Column Family is mandatory. This parameter indicates a set of column families in an HBase cluster.
    Validity Period
    Allowed
    • Role: MRS role.
    Exceptions
    Blocked
    • Role: MRS role.
Creating a Yarn Permission Policy
    Figure 16 Resource Permission Settings page
  3. Click Configure to the right of the Yarn component, and click Create in the upper part of the page that is displayed.
    Figure 17 Creating a Yarn permission policy
    Figure 18 Configuring a Yarn policy
    Table 7 Parameters of a Yarn permission policy
    Policy Type
    Policy Status
    Overwrite
    Audit Log
    Policy Name
    Queue
    Resource scheduling queue in the Yarn service.
    Validity Period
    Allowed
    • Role: MRS role.
    Exceptions
    Blocked
    • Role: MRS role.
Creating a Kafka Permission Policy
    Figure 19 Resource Permission Settings page
  3. Click Configure to the right of the Kafka component, and click Create in the upper part of the page that is displayed.
    Figure 20 Creating a Kafka permission policy
    Figure 21 Configuring a Kafka policy
    Table 8 Parameters of a Kafka permission policy
    Policy Type
    Policy Status
    Overwrite
    Audit Log
    Policy Name
    Policy Conditions
    Range of IP addresses that can access the Kafka topic.
    Topic
    The message topic of a Kafka cluster.
    Validity Period
    Allowed
    • Role: MRS role.
    • Policy Conditions: the range of IP addresses that can access the Kafka topic.
    Exceptions
    Blocked
    • Role: MRS role.
Creating a Storm Permission Policy
    Figure 22 Resource Permission Settings page
  3. Click Configure to the right of the Storm component, and click Create in the upper part of the page displayed.
    Figure 23 Creating a Storm permission policy
    Figure 24 Configuring a Storm policy
    Table 9 Parameters of a Storm permission policy
    Policy Type
    Policy Status
    Overwrite
    Audit Log
    Policy Name
    Topology
    Tasks in a Storm cluster.
    Validity Period
    Allowed
    • Role: MRS role.
    Exceptions
    Blocked
    • Role: MRS role.
