Help Center/ DataArts Studio/ User Guide/ Management Center/ Managing Notebook Resources
Updated on 2026-09-14 GMT+08:00
Management Center provides central management of notebook resources. It allows the workspace administrator to centrally manage the runtime environments and compute resources of all tenants.
DataArts Factory provides an interactive development environment and a fully managed, cloud-based version of JupyterLab that is ready to use out of the box. A runtime environment is the basic notebook development environment. You can bind compute resources, which provide compute engines for you to develop notebook jobs easily at lower costs. In Management Center, you can create, enable, disable, and delete notebook runtime environments, and bind and unbind compute resources.
Currently, the notebook function is restricted. To use it, contact customer service or technical support.
Currently, this function is available only in the Jakarta region. This function is subject to the ECS resources in the current region.
Currently, the notebook function is in the OBT phase of the first version. It is recommended that you use it for personal development and testing only.
  • Runtime environment
  • Compute resources
    • You have created an MRS cluster before binding MRS Spark compute resources.
    • You have created a compute resource workspace and endpoint before binding Fabric SQL compute resources.
Notes and Constraints
  • Runtime environments
    • You can create a maximum of 10 notebooks in the current workspace.
    • The permissions of preset roles are as follows:
      • If you are the administrator of the current workspace or have the DAYU Administrator or Tenant Administrator permissions, you can create runtime environments owned by yourself and delete, operate, query, and edit all runtime environments in the workspace. To create a runtime environment for another user, you need to create a runtime environment owned by yourself first, and then change the environment owner to the target user.
      • As a developer, you can create, delete, operate, query, and edit runtime environments owned by yourself. However, you cannot modify the runtime environments owned by others.
    • If you are assigned a custom role and have the create permission, you can only create and manage runtime environments owned by yourself. If you have the delete, operate, query, and edit permissions, you can perform the corresponding operations on all runtime environments in the workspace. The query permission is the prerequisite for performing other operations. You cannot delete or edit runtime environments for which you do not have the query permission. You can change the owner of a runtime environment only if you have the edit permission on the environment. For details about how to create a custom role, see (Optional) Defining a Workspace Role.
    • If you are assigned both a preset role and a custom role, you have permissions of both roles.
  • Compute resources
      • You can bind, unbind, query, and edit compute resources only if you are the workspace administrator or have the DAYU Administrator or Tenant Administrator permissions.
      • As a developer, you can only view compute resources.
      • As an operator, you can view and edit compute resources.
    • If you are assigned a custom role and have the create, delete, query, and edit permissions, you can bind, unbind, query, and edit all compute resources in the workspace. For details about how to create a custom role, see (Optional) Defining a Workspace Role.
    • Only MRS Spark and Fabric SQL resources are supported.
    • To bind an MRS compute engine, you must create an MRS 3.5.1-LTS cluster first. Spark 3.3.1 is supported.
Creating a Runtime Environment
  1. Log in to the DataArts Studio console.
    For details, see Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click Management Center.
  3. In the navigation pane on the left, choose Notebook Resources. On the displayed page, click the Notebook Runtime Environment tab.
    Figure 1 Notebook Runtime Environment
  4. Click Create Runtime Environment and configure the parameters listed in Table 1.
    Table 1 Parameters for creating a runtime environment
    Name
    Name of the runtime environment
    Owner
    Owner of the runtime environment. The default value is the user who created the environment.
    Resource Group
    Resource group to which the notebook belongs. The runtime environment obtains resources from the resource group for executing notebook scripts. If you have not purchased a notebook resource group, purchase one by referring to Managing Notebook Resource Groups.
    Runtime Resource Specifications
    Resource specifications for running notebook jobs
    Image. For details about how to view system images, see Managing Images.
    Auto stop
    If you select this option, the runtime environment will automatically stop if no operation is performed within the specified period. Enter a value from 1 to 72, in hours. The default value is 1 hour.
    Description (Optional)
    Description. A maximum of 1,000 characters are allowed.
  5. Click Create.
    After the runtime environment is created, click Enable in the Operation column to activate the notebook job development and runtime environment. Then you can develop notebook jobs in DataArts Factory. For details about how to develop notebook jobs, see Using a Notebook Instance for Online Development and Debugging.
Managing Runtime Environments
  • Running a runtime environment: Click Run in the Operation column to enable a runtime environment for notebook job development.
  • Stopping a runtime environment: Click Stop in the Operation column to stop a runtime environment for notebook job development.
  • Deleting a runtime environment: Click Delete in the Operation column, enter DELETE, and click OK to delete a runtime environment. After a runtime environment is deleted, all the job development scripts created in the environment will also be deleted. Exercise caution when performing this operation.
  • Editing a runtime environment: Locate a runtime environment in stopped state and click Edit in the Operation column. You can change the owner of an environment only if you are the current workspace administrator, have the permissions of the DAYU Administrator or Tenant Administrator, or have been assigned a custom role that has the edit permission of the environment.
  • Viewing details about a runtime environment: Click the name of a runtime environment to view its details.
Binding or Unbinding a Compute Resource
Binding a Compute Resource
  3. In the navigation pane on the left, choose Notebook Resources. On the displayed page, click the Compute Resources tab.
    Figure 2 Computing Resources
  4. Click Bind Compute Resource and configure the parameters listed in Table 2.
    Table 2 Parameters for binding compute resources
    Resource Type
    Compute engine for notebook job development. MRS Spark and Fabric SQL are supported.
    Resource Name
    Compute resource name
    MRS Cluster
    If you select MRS Spark for Resource Type, select an MRS cluster.
    For details about how to buy a cluster, see Buying MRS Clusters. After the MRS cluster is created, you can view the basic information about the MRS cluster in Active Clusters.
    Compute Resource Workspace
    This parameter is mandatory when Fabric SQL is selected for Resource Type. A workspace is the basic unit of Fabric. Select a workspace for Fabric SQL.
    You can create a resource workspace on the DataArts Fabric console. For details about how to create a workspace, see Creating a Workspace.
    Endpoint
    If you select Fabric SQL for Resource Type and select a compute resource workspace, configure an endpoint, which is the compute resource required for running SQL tasks.
    For details about how to create a SQL endpoint, see Creating a SQL Endpoint.
  5. Click OK to bind the compute resource.
Click Unbind Compute Resource in the Operation column of a compute resource. In the displayed dialog box, enter UNBIND and click OK to unbind the compute resource. After the compute resource is unbound, it can no longer be used for notebook job development. Exercise caution when performing this operation.
Managing Compute Resources
  • Editing a compute resource: Click Edit in the Operation column of a compute resource. The resource type cannot be changed.
  • Viewing compute resource details: Click the name of a compute resource to view its details.
