Data Migration
Functions
This node is used to execute an offline or real-time processing migration job.
Parameters
Table 1 and Table 2 describe the parameters of the Data Migration node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
CDM Cluster Name |
Yes |
Select CDM clusters. To view the cluster list, click |
CDM Job Message Body |
Yes |
Enter the CDM job message body in JSON format. To obtain the JSON message body, perform the following steps:
Parameters |
Mandatory |
Description |
Node Status Polling Interval (s) |
Yes |
How often the system checks whether the node execution is complete. The value ranges from 1 to 60 seconds. |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
Retry upon Failure |
Yes |
Whether to re-execute a node if it fails to be executed.
Policy for Handling Subsequent Nodes If the Current Node Fails |
Yes |
Operation that will be performed if the node fails to be executed. Possible values:
Enable Dry Run |
No |
If you select this option, the node will not be executed, and a success message will be returned. |
Task Groups |
No |
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
