Help Center/ DataArts Studio/ User Guide/ DataArts Factory/ Script Development/ (Optional) Managing Scripts/ Viewing Script References
Updated on 2025-09-09 GMT+08:00
This section describes how to view the references of a script or all the scripts in a folder.
A script has been developed based on Developing Scripts.
- Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
- On the DataArts Studio console, locate a workspace and click DataArts Factory.
- In the left navigation pane of DataArts Factory, choose .
- To view the references of a script, right-click the script and select View Reference.
To view the references of all the scripts in a folder, right-click the folder and select View Reference.
- In the displayed dialog box, you can view the references of a script or all the scripts in the folder. Figure 1 References of a script
Parent topic: (Optional) Managing Scripts
