ETL Job
Functions
The ETL Job node is used to extract data from a specified data source, preprocess the data, and import the data to the target data source.
The destination is the ETL Job node of DWS and does not support scheduling using an agency. You are advised to use a public IAM account with better compatibility for scheduling. For details, see Configuring a Scheduling Identity.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the ETL Job node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of a node. The name must contain 1 to 128 characters, including only letters, numbers, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
ETL Configuration |
Yes |
Click The supported source data types are DLI, OBS and MySQL.
Configure SQL Template |
No |
Click Obtain Template to obtain an SQL template. |
Parameter |
Mandatory |
Description |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will be executed again. |
Retry upon Failure |
Yes |
Whether to re-execute a node if it fails to be executed. Possible values:
Policy for Handling Subsequent Nodes If the Current Node Fails |
Yes |
Operation that will be performed if the node fails to be executed. Possible values:
Enable Dry Run |
No |
If you select this option, the node will not be executed, and a success message will be returned. |
Task Groups |
No |
Select a task group. If you select a task group, you can control the maximum number of concurrent nodes in the task group in a fine-grained manner in scenarios where a job contains multiple nodes, a data patching task is ongoing, or a job is rerunning. |
Parameter |
Description |
Input |
Add |
Click Add. In the Type drop-down list, select the type to be created. The value can be DWS, OBS, CSS, HIVE, DLI, or CUSTOM. |
OK |
Click OK to save the parameter settings. |
Cancel |
Click Cancel to cancel the parameter settings. |
Modify |
Click |
Delete |
Click |
View Details |
Click |
Output |
Add |
OK |
Cancel |
Modify |
Click |
Delete |
Click |
View Details |
Click |
