Updated on 2025-09-09 GMT+08:00
Moving a Script or Script Directory
You can move a script file from one directory to another or move a script directory to another directory.
A script has been developed based on Developing Scripts.
  1. Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console.
  2. On the DataArts Studio console, locate a workspace and click DataArts Factory.
  3. In the left navigation pane of DataArts Factory, choose Data Development > Develop Script.
  4. Move a script or script directory.
    Method 1: right-click
    1. In the script directory, right-click a script or script folder and select Move.
      Figure 1 Selecting Move
    2. In the displayed dialog box, configure related parameters. Table 1 describes the parameters.
      Figure 2 Moving a script
      Figure 3 Move a directory
      Table 1 Parameters for moving a script or directory
      Select Directory
      Directory to which the script or script directory is to be moved. The parent directory is the root directory by default.
    3. Click OK to move the script or directory.
    Method 2: drag-and-drop
    Select a script or script folder and drag and drop it to the target folder.
