Updated on 2025-09-09 GMT+08:00
From DWS
If the source link of a job is a DWS link, configure the source job parameters based on Table 1.
Table 1 Parameter description
Type
Example Value
Basic parameters
Use SQL Statement
Whether you can use SQL statements to export data from a relational database
No
SQL Statement
When Use SQL Statement is set to Yes, enter an SQL statement here. CDM exports data based on the SQL statement.
  • SQL statements can only be used to query data. Join and nesting are supported, but multiple query statements are not allowed, for example, select * from table a; select * from table b.
  • With statements are not supported.
  • Comments, such as -- and /*, are not supported.
  • Addition, deletion, and modification operations are not supported, including but not limited to the following:
    • load data
    • delete from
    • alter table
    • create table
    • drop table
    • into outfile
  • If the SQL statement is too long, the request fails to be delivered. If you continue to create a job, the system displays an error message indicating that the request is incorrect. In this case, you need to simplify or clear the SQL statement and try again.
select id,name from sqoop.user;
Schema/Tablespace
Name of the schema or tablespace from which data will be extracted. This parameter is displayed when Use SQL Statement is set to No. Click the icon next to the text box to go to the page for selecting a schema or directly enter a schema or tablespace.
If the desired schema or tablespace is not displayed, check whether the login account has the permissions required to query metadata.
The parameter value can contain wildcard characters (*), which is used to export all databases whose names start with a certain prefix or end with a certain suffix. Examples:
  • SCHEMA* indicates that all databases whose names starting with SCHEMA are exported.
  • *SCHEMA indicates that all databases whose names ending with SCHEMA are exported.
  • *SCHEMA* indicates that all databases whose names containing SCHEMA are exported.
SCHEMA_E
Table Name
Name of the table from which data will be extracted. This parameter is displayed when Use SQL Statement is set to No. Click the icon next to the text box to go to the page for selecting the table or directly enter a table name.
If the desired table is not displayed, check whether the table exists or whether the login account has the permission to query metadata.
This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
This parameter can be set to a regular expression to export all databases that meet the rule. For example, if Table Name is set to user_[0-9]{1,2}, tables from user_0 to user_9 and from user_00 to user_99 are matched.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development jobOffset) rather than (Actual start time of the CDM jobOffset).
table
Advanced attributes
WHERE Clause
WHERE clause used to specify the data extraction range. This parameter is displayed when Use SQL Statement is set to No. If this parameter is not set, the entire table is extracted.
You can set a date macro variable to extract data generated on a specific date. For details, see Incremental Migration of Relational Databases.
DS='${dateformat(yyyy-MM-dd,-1,DAY)}'
Retain One Decimal Place for Date Values
Whether to retain one decimal place for date values
Yes
Partition Column
This parameter is displayed when Use SQL Statement is set to No, indicating a field used to split data during data extraction. CDM splits a job into multiple tasks based on this field and executes the tasks concurrently. Fields with data distributed evenly are used, such as the sequential number field.
Click the icon next to the text box to go to the page for selecting a field or directly enter a field.
The following types of partition columns are supported: TINYINT, SMALLINT, INTEGER, BIGINT, REAL, FLOAT, DOUBLE, NUMERIC, DECIMAL, BIT, BOOLEAN, DATE, TIME, and TIMESTAMP. It is recommended that the partition column have an index.
id
Null in Partition Column
Whether the partition column can contain null values
During concurrent extraction, if the partition column does not contain null, set this parameter to No to improve performance. If you are not sure whether the partition column contains null, set this parameter to Yes to avoid data loss.
Yes
