Buying a DataArts Migration Resource Group Incremental Package
- When you buy a pay-per-use DataArts Migration resource group incremental package, the system automatically creates a resource group required by real-time data integration jobs based on the specifications you set for the incremental package.
- When you buy a DataArts Migration resource group incremental package which is billed based on a package, the system does not automatically create a resource group. Instead, you can use a resource group you have obtained on the DataArts Studio console for 745 hours each month within the validity period of the incremental package.
DataArts Migration resource groups can be used in the following scenarios:
They can be used to create and run real-time processing migration jobs to migrate data to the cloud or ingest data into the data lake.
By default, a DataArts Studio instance does not contain DataArts Migration resource groups. If you want to migrate data in real time, create a DataArts Migration resource group incremental package.
Context
- When you create a DataArts Migration resource group incremental package, the system automatically creates a resource group required by real-time data integration jobs based on the specifications you set for the incremental package.
- When buying a DataArts Migration resource group incremental package (pay-per-use resource package), pay attention to the following:
- When you buy a DataArts Migration resource group incremental package which is billed based on a pay-per-use package, the system does not automatically create a resource group for real-time processing migration jobs. Instead, you can use a resource group you have obtained on the DataArts Studio console for 745 hours each month within the validity period of the incremental package and in a specified region.
- If you have one or more resource groups in a region, the duration quota of your resource package will be deducted first. Any usage beyond the quota will be billed in pay-per-use mode. (If a resource package is shared by multiple clusters, the available package duration may be insufficient in each subscription period.)
For example, if you purchase a one-month package (745 hours/month) and two resources are associated with the package, 372.5 hours (about 15.5 days) can be allocated to each resource group within the one-month subscription. Any usage beyond the allocated hours will be billed in pay-per-use mode.
- If you purchase a package and do not associate it with any resource group, the duration quota in the package will not be consumed and the validity period of the package will not be extended as well. Therefore, you are advised to make a plan before buying a package.
- If you want to enjoy the preferential price of the yearly/monthly incremental package, you can buy a yearly/monthly incremental package and then buy a pay-per-use incremental package which is in the same region and has the same specifications as the yearly/monthly incremental package.
- If you buy a pay-per-use incremental package and then a yearly/monthly incremental package in the same region and with the same specifications as the pay-per-use incremental package, the fees generated before you buy the yearly/monthly incremental package are charged in pay-per-use mode, and the subsequent fees are charged based on the yearly/monthly incremental package.
- You can locate a DataArts Studio instance, click More, and select View Packages to view your incremental packages.
- The prices of resource groups vary depending on their specifications. For details, see Billing. You can also access the Price Calculator of DataArts Studio and select a region and specifications to quickly obtain the price of a resource group.
Buying a Pay-Per-Use DataArts Migration Resource Group
When you buy a pay-per-use incremental package, the system automatically creates a resource group required by real-time data migration jobs based on the specifications you set for the incremental package.
- You can buy a resource group in either of the following ways:
- Method 1
Locate an enabled instance and click Buy.
Figure 1 Incremental package
- Method 2
- Locate an instance and click Access.
- In the upper right corner, click Buy.
- Method 3
- Locate an instance, click More, and select Resources. Figure 2 Accessing Resources
- On the Real-Time Resources tab page, click Buy Resource Group. Figure 3 Buying a resource group
- Method 1
- On the displayed page, set parameters based on Table 1. Figure 4 Buying a DataArts Migration resource group
Table 1 Parameters for the DataArts Migration resource group incremental package Parameter
Package
Billing Mode
Select Pay per Use.
Name
Enter the resource group name.
Enter a description for the DataArts Migration resource group.
Specifications
Select the specifications for the resource group, including the CU value, applicable environment, and maximum number of jobs that can be created.
The maximum number of migration tasks or jobs that can be created varies depending on the resource group specifications. Select the specifications that suit your needs. A maximum of 200 tables can be created for a single job (at least 2 CUs are required).
Small: 16 CUs and a maximum of 7 jobs This option is applicable to tests and does not support high availability. It is not recommended.
Medium: 64 CUs and a maximum of 32 jobs
Large: 96 CUs and a maximum of 48 jobs
Super-large: 128 CUs and a maximum of 64 jobs
Network Segment
Recommended network segments:
- 10.0.0.0–10.255.0.0/8–19
- 172.16.0.0–172.31.0.0/12–19
- 192.168.0.0~192.168.0.0/16 ~19 NOTE:
- To use VPC peering connections, set a network segment that does not overlap with that of the source and destination cluster or instance. If they overlap, the network will be disconnected.
- Restricted by the CCE logic, the maximum length of the network segment mask is 19 bits. Network segments with a mask longer than 20 bits are not supported.
Discount Quota (Hour)
A discount package is prepaid by month or year. Compared with pay-per-use billing, the fee is reduced by 15% to 29%.
- You cannot modify the specifications of an existing resource group. If you need higher specifications, create another resource group.
- You can unsubscribe from a pay-per-use resource package in use. For details, see Overview of Unsubscription Rules.
- Click Buy Now, confirm the settings, and click Next. If the resource group fails to be created and a quota issue is displayed, contact the service personnel to apply for a quota.
- Go to the corresponding workspace to view the DataArts Migration resource group you have purchased.
Buying a DataArts Migration Resource Group Billed Based on a Package
If you want to enjoy the favorable price of a package, you can buy an incremental package billed by package and then buy a pay-per-use incremental package which is in the same region and has the same specifications as the incremental package billed by package.
- On the displayed page, set the following parameters:
- Select DataArts Migration resource group for Package.
- Select Pay-per-Use Package for Billing Mode.
- Specify a validity period in Required Duration for the package.
- Enter the number of subscribed packages in Quantity. For example, if you set Required Duration to 1 month and Quantity to 2, you will have a 1,490-hour quota in one month.
- (Optional) Create a resource group.
- Enable Create Resource Group to create a data migration resource group in the same region and with the same specifications as the package you purchase. Then you can enjoy the favorable price of this package. If you select this option, you need to set the following parameters:
- Name: Enter the name of the data migration resource group.
- Description: Enter a description for the DataArts Migration resource group.
- IPv4 Network Segment: Recommended network segments include 10.0.0.0–10.255.0.0/8–19, 172.16.0.0–172.31.0.0/12–19, and 192.168.0.0–192.168.0.0/16–19.
- Associated Workspace: Associate the data migration resource group with a DataArts Studio workspace so that you can select a specified computing resource group when creating a real-time data migration job.
- Enterprise Project: Select an enterprise project associated with the DataArts DataService Exclusive cluster of DataArts Studio. An enterprise project facilitates management of cloud resources. For details, see Enterprise Management User Guide.
- If you do not enable Create Resource Group, the system will not automatically create a data migration resource group after the purchase. You need to buy a pay-per-use incremental package in the same region and with the same specifications as this package by following the instructions in Buying a Pay-Per-Use DataArts Migration Resource Group. Then you can enjoy the favorable price of this package.
- Click Buy Now, confirm the specifications, and click Next.
