Updated on 2025-07-25 GMT+08:00
Buying an Incremental Package for Technical Asset Quantity
This package is used to increase the quota of the technical asset quantity.
The maximum number of technical assets varies depending on the DataArts Studio instance version. This quota is calculated based on the total number of tables and OBS files in DataArts Catalog. You can locate a DataArts Studio instance, click More, and select Quota Usage to view this quota.
If the number of your technical assets is close to or has reached the upper limit, you are advised to purchase a technical asset quantity incremental package.
Context
  • For details about the specifications of DataArts Studio instances of different versions, see Version Specifications.
  • You can locate a DataArts Studio instance, click More, and select View Packages to view your incremental packages.
  • You can locate a DataArts Studio instance, click More, and select Quota Usage to view the quota usage of the instance. You can also locate a workspace on the Workspaces page and click Quota Usage in the Operation column to view the quota usage of the workspace.
Setting the Alarm Threshold for Quota Usage
Before buying a quota expansion incremental package, you can set the alarm threshold for quota usage. When the threshold is reached and an alarm is triggered, you need to buy a quota expansion incremental package. Otherwise, your services may be affected.
To set the alarm threshold for quota usage, perform the following steps:
  1. Locate a DataArts Studio instance, click More, and select Alarm threshold.
    Figure 1 Alarm threshold
  2. Set the alarm threshold to a value from 0 to 100. Value 0 indicates that no alarm will be generated. When the quota usage exceeds the configured alarm threshold, the Simple Message Notification (SMN) service triggers an SMS or email alarm.
  3. Go to the SMN console, choose Topic Management > Topics, and locate the DGC_Topic_Manager_Schedule_Alarm_Project name_Instance ID topic.
    • To obtain the project name, perform the following steps:
      1. Register with and log in to the management console.
      2. Hover the cursor on the username in the upper right corner and select My Credentials from the drop-down list.
      3. On the API Credentials page, obtain the account name, account ID, IAM username, and IAM user ID, and obtain the project and its ID from the project list.
    • To obtain the instance ID, perform the following steps:
      1. On the DataArts Studio console, locate a workspace and click any module, such as Management Center.
      2. On the Management Center page, obtain the values of instanceId and workspace in the browser address bar, which are the instance ID and workspace ID, respectively.
        As shown in Figure 2, the instance ID is 6b88…2688, and the workspace ID is 1dd3bc…d93f0.
        Figure 2 Obtaining the instance ID and workspace ID
  4. In the Operation column of the topic, click Add Subscription. Select SMS or Email for Protocol, and enter the mobile number or email address for receiving alarm notifications.
    Figure 3 Adding a subscription
  1. Locate an enabled instance and click Buy.
  2. On the displayed page, set the following parameters:
    • Package: Select Technical asset quantity.
    • Billing Mode: Only Package is supported.
    • Flavor: Select a flavor that meets your needs.
    • Required Duration: Select the validity period of the package.
    • Auto-renew: You can select it to enable automatic renewal of the subscription by month or year. If you choose the monthly billing mode, your subscription will be automatically renewed each month. If you choose the yearly billing mode, your subscription will be automatically renewed each year.
  3. Click Buy Now, confirm the specifications, and click Next.
  4. After you purchase the package, its quota will be added to the default quota.
