Updated on 2026-09-14 GMT+08:00
Buying a DataArts DataService Exclusive Cluster Incremental Package
This package corresponds to a DataArts DataService Exclusive cluster. After you buy a DataArts DataService incremental package, the system automatically creates a cluster based on your selected specifications.
DataArts DataService is a standard data service platform that allows you to generate data APIs quickly from data tables. Using the APIs, you can open your data in a simple, fast, low-cost, and secure way. To use DataArts DataService, you must buy a DataArts DataService Exclusive cluster first.
A DataArts Studio instance does not contain a DataArts DataService Exclusive cluster. To use DataArts DataService, you must buy a DataArts DataService Exclusive cluster incremental package.
Context
  • You can locate a DataArts Studio instance, click More, and select View Packages to view your incremental packages.
  1. On the instance list, click Buy on the card of the instance you have enabled.
    Figure 1 Buying an incremental package
  2. On the displayed page, set parameters based on Table 1.
    Table 1 Parameters for buying an exclusive DataArts DataService instance
    Package
    Select DataArts DataService.
    Billing Mode
    Currently, Yearly/Monthly is supported.
    The workspace for which you want to use the incremental package. For example, if you want to use DataArts DataService Exclusive in workspace A of the DataArts Studio instance, select workspace A. After you buy an exclusive DataArts DataService cluster, you can view it in workspace A.
    If you want to use the cluster in other workspaces, you can share it with those workspaces by referring to Managing Cluster Sharing.
    AZ
    Select the AZ where the DataArts DataService Exclusive cluster is located.
    Select One AZ or Multiple AZs. Multiple AZs is recommended.
    • One AZ: Nodes of the DataArts DataService Exclusive cluster are deployed in the same AZ.
    • Multiple AZs: Nodes of the DataArts DataService Exclusive cluster are deployed in 2 to 10 AZs.
    For details, see Regions and AZs.
    Name
    The cluster name must start with a letter and can contain only letters, digits, hyphens (-), and underscores (_). It must contain at least five characters.
    A description of the exclusive DataArts DataService cluster.
    Version
    Cluster version of the exclusive DataArts DataService cluster.
    Cluster Details
    The number of APIs supported varies depending on the instance specifications.
    Public Address
    Enable this function. When the cluster is created, a new EIP is automatically bound to the cluster. You can use this EIP to call the APIs of the exclusive cluster. The EIP assigned through this function is free.
    If you want to call APIs locally or across networks, you are advised to enable this function.
    Bandwidth
    Bandwidth range on the Internet.
    VPC
    VPC, subnet, and security group to which the DataArts DataService Exclusive cluster in the DataArts Studio instance belongs.
    Cloud resources (such as ECSs) within the same VPC, subnet, and security group can call APIs using the private IP address of the DataArts DataService Exclusive instance. Deploy the DataArts DataService Exclusive cluster in the same VPC, subnet, and security group as your other services to facilitate network configuration and secure network access.
    For details about the operations on VPCs, subnets, and security groups, see Virtual Private Cloud User Guide.
    • After a DataArts DataService Exclusive cluster is created, the VPC, subnet, and security group of the cluster cannot be changed. Exercise caution when setting them during the cluster creation.
    • If Enabling the public IP address is selected, the security group must allow access from ports 80 (HTTP) and 443 (HTTPS) in the inbound direction.
    • You can select a VPC subnet shared by the VPC owner when you buy a DataArts DataService Exclusive cluster. Through VPC subnet sharing, you can easily configure and manage multiple accounts' resources at low costs. For details about how to share a VPC subnet, see VPC Sharing.
    Subnet
    Security Group
    Managing Cluster Resources Using an Enterprise Project
    Enterprise project associated with the exclusive DataArts DataService cluster. An enterprise project facilitates management of cloud resources. For details, see Enterprise Management User Guide.
    Nodes
    N/A
    Required Duration
    N/A
  3. Click Buy Now. If there are no changes made to the specifications, submit the order.
