To Hive
If the destination link of a job is a Hive link, configure the destination job parameters based on Table 1.
Parameter | Description | Example Value |
Database Name | Database name. Click the icon next to the text box. The dialog box for selecting the database is displayed. | default |
Table Name | Destination table name. Click the icon next to the text box. The dialog box for selecting the table is displayed. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | TBL_X |
Auto Table Creation | This parameter is displayed only when the source is a relational database. The options are as follows:
| Non-auto creation |
Source side null value conversion value | Value to which the source null value is converted
| TO_NULL |
Clear Data Before Import | Whether the data in the destination table is cleared before data import. The options are as follows:
| Yes |
Processing mode of newline characters | Policy for processing the newline characters in the data written to Hive textfile tables
| Delete |
Hive Table Partition Field | This parameter is unavailable when Auto Table Creation is set to Non-auto Creation. Partition fields for creating a Hive table. Use commas (,) to separate multiple fields. | A,B |
Table Path | This parameter is unavailable when Auto Table Creation is set to Non-auto Creation. It specifies the table path. | - |
Storage Format | This parameter is unavailable when Auto Table Creation is set to Non-auto Creation. It specifies the storage format.
TEXTFILE data is stored in plaintext. If data contains special characters, data may be written incorrectly. Exercise caution when using this format. The ORC format is recommended. | ORC |
ClearDataMode | This parameter is available when Clear Data Before Import is set to Yes. It specifies the mode for clearing data in the Hive table.
| TRUNCATE |
Partitions info | This parameter is available when Clear Data Before Import is set to Yes. If the destination is a partitioned table, you must specify partitions.
| Single partition: year=2020,location=sun Multiple partitions: ['year=2020,location=sun', 'year=2021,location=earth'] Partitions of the previous day: day='${dateformat(yyyy-MM-dd HH:mm:ss, -1, DAY)}', |
Executing Analyze Statements | After all data is written, the ANALYZE TABLE statement is asynchronously executed to accelerate query of data from Hive tables. Run the following SQL statements:
NOTE: Parameter Executing Analyze Statements applies only to the migration of a single table. Running the ANALYZE statements may exert pressure on Hive. | Yes |
Maximum memory size of the internal write queue | If the memory is insufficient, change the value of this parameter as needed. If the value is too small, the migration speed will be affected. The value ranges from 1 to 128 MB. The default value is empty, indicating that there is no limit. If you set a value beyond the range, there is no limit. | 16 |
Maximum memory size of the internal conversion queue | If the memory is insufficient, change the value of this parameter as needed. If the value is too small, the migration speed will be affected. The value ranges from 1 to 128 MB. The default value is empty, indicating that there is no limit. If you set a value beyond the range, there is no limit. | 16 |
- How data is written to a dynamic partition and a static partition using Hive LoadOverwrite:
CDM Hive LoadOverwrite depends on the native Hive syntax 'LOAD DATA [LOCAL] INPATH 'filepath' [OVERWRITE] INTO TABLE tablename [PARTITION (partcol1=val1, partcol2=val2 ...)]'. For details about Hive syntax, see the official Hive website.
During data writing, temporary data files are generated. After data is written, the LOAD DATA OVERWRITE SQL statement is executed to write the temporary data files to the destination table.
Example:
- The source table is a MySQL table with dt as the partition date. The table creation statement is as follows:
CREATE TABLE `demo` ( `id` varchar(10) DEFAULT NULL, `dt` date DEFAULT NULL ) ENGINE=InnoDB DEFAULT CHARSET=utf8
- The destination table is a Hive partitioned table with dt as the partition date. The table creation statement is as follows:
CREATE TABLE `demo` ( `id` varchar(10) ) PARTITIONED BY (`dt` date)
- Write data.
To write data to a single partition, that is, a static partition, you can configure the partition information.
Figure 1 Configuring partition information
To write data from multiple partitions at the source to multiple destination partitions (dynamic partitioning), you do not need to configure partition information. Instead, you can select the partition fields to be migrated in field mapping to write data from the partition fields at the source to the corresponding partitions at the destination.Figure 2 Configuring partition information
Figure 3 Selecting the partition fields to be migrated
- If the source Hive contains both the array and map types of data, the destination table format can only be the ORC or parquet complex type. If the destination table format is RC or TEXT, the source data will be processed and can be successfully written.
- As the map type is an unordered data structure, the data type may change after a migration.
- If Hive serves as the migration destination and the storage format is Textfile, delimiters must be explicitly specified in the statement for creating Hive tables. The following is an example:
CREATE TABLE csv_tbl( smallint_value smallint, tinyint_value tinyint, int_value int, bigint_value bigint, float_value float, double_value double, decimal_value decimal(9, 7), timestamp_value timestamp, date_value date, varchar_value varchar(100), string_value string, char_value char(20), boolean_value boolean, binary_value binary, varchar_null varchar(100), string_null string, char_null char(20), int_null int ) ROW FORMAT SERDE 'org.apache.hadoop.hive.serde2.OpenCSVSerde' WITH SERDEPROPERTIES ( "separatorChar" = "\t", "quoteChar" = "'", "escapeChar" = "\\" ) STORED AS TEXTFILE;
