From DIS
The data in the message body is a record in CSV format that supports multiple delimiters. Messages cannot be parsed in binary or other formats.
If the source link of a job is a DIS link, configure the source job parameters based on Table 1.
| Category | Parameter | Description | Example Value |
| Basic parameters | DIS Stream | DIS stream name | dis |
| Permanent Running | Whether a job runs permanently. Even if you enable the job to run permanently, the job will fail if the DIS system is interrupted. | Yes | |
| DIS Partition ID | ID of the DIS partition. You can enter multiple partition IDs separated by commas (,). | 0,1,2 | |
| Offset | Initial offset when data is pulled from DIS
| Latest | |
| Application Name | Unique identifier of the consumer application to be used. If no application exists, CDM creates one automatically. | cdm | |
| Data Format | Format used for parsing data. The options are as follows:
| Binary | |
| Field Delimiter | This parameter is displayed when Data Format is set to CSV. The default value is comma (,). To set the Tab key as the delimiter, set this parameter to \t. | , | |
| Record Delimiter | This parameter is displayed when Data Format is set to CSV or JSON. It is used to separate each two records. | , | |
| Advanced attributes | Max. Poll Records | (Optional) Maximum number of records per poll | 100 |
