From FTP/SFTP
If the source link of a job is an FTP or SFTP link, configure the source job parameters based on Table 1.
Advanced attributes are optional and not displayed by default. You can click Show Advanced Attributes to display them.
Category | Parameter | Description | Example Value |
Basic parameters | Source Directory/File | Directory or file path from which data will be extracted. You can enter a maximum of 50 file paths. By default, the file paths are separated by vertical bars (|). You can also customize a file separator. For details, see Migration of a List of Files. Directory from which data is to be migrated. All files (including all nested subdirectories and their subfiles) in the directory will be migrated. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | /ftp/a.csv|/ftp/b.txt |
File Format | Format in which CDM parses data. The options are as follows:
NOTE: If the destination is OBS, only the binary format is supported. | CSV | |
JSON Type | This parameter is displayed only when File Format is set to JSON. Type of a JSON object stored in a JSON file. The options are JSON object and JSON array. | JSON object | |
JSON Reference Node | This parameter is used only when File Format is set to JSON and JSON Type is set to JSON Object. CDM parses the data under the JSON node. If the node's corresponding data is a JSON array, the system will extract data from the array in the same pattern. Use periods (.) to separate multi-layer nested JSON nodes. | data.list | |
Advanced attributes | Use rfc4180 Parser | This parameter is displayed only when File Format is set to CSV. It specifies whether to use the rfc4180 parser to parse CSV files. | No |
Line Separator | Lind feed character in a file. By default, the system automatically identifies \n, \r, and \r\n. This parameter is displayed only when File Format is set to CSV. | \n | |
Field Delimiter | Character used to separate fields in the file. To set the Tab key as the delimiter, set this parameter to \t. This parameter is displayed only when File Format is set to CSV. | , | |
Use Quote Character | If you set this parameter to Yes, the field delimiters in the encircling symbol are regarded as a part of the string value. Currently, the default encircling symbol of CDM is ". | No | |
Using Escape Char | If you select Yes, the backslash (\) in the data row is used as an escape character. If you select No, the backslash (\) in the CSV file will not be escaped. CSV supports only the backslash (\) as the escape character. | Yes | |
Use RE to Separate Fields | Whether to use regular expressions to separate fields. If you set this parameter to Yes, Field Delimiter becomes invalid. This parameter is displayed only when File Format is set to CSV. | Yes | |
Regular Expression | This parameter is available only when Using RE to separate fields is set to Yes. Regular expression used to separate fields. For details about regular expressions, see Regular Expressions for Separating Semi-structured Text. | ^(\d.*\d) (\w*) \[(.*)\] ([\w\.]*) (\w.*).* | |
Use First Row as Header | This parameter is displayed only when File Format is set to CSV. When you migrate a CSV file to a table, CDM writes all data to the table by default. If you set this parameter to Yes, CDM uses the first N rows of the CSV file as the heading row and does not write the row to the destination table. | Yes | |
Encoding Type | Encoding type, for example, UTF-8 or GBK. You can set the encoding type for text files only. This parameter is invalid when File Format is set to Binary. | UTF-8 | |
Compression Format | The options are as follows:
| NONE | |
Compressed File Suffix | This parameter is displayed when Compression Format is not NONE. This parameter specifies the extension of the files to be decompressed. The decompression operation is performed only when the file name extension is used in a batch of files. Otherwise, files are transferred in the original format. If you enter * or leave the parameter blank, all files are decompressed. | * | |
Start Job by Marker File | Whether to start a job by a marker file. A job is only started if there is a marker file for starting the job in the source path. If there is no marker file, the job will be suspended for a period of time specified by Suspension Period. | Yes | |
File Separator | File separator. If you enter multiple file paths in Source Directory/Files, CDM uses the file separator to identify files. The default value is |. | | | |
Marker File | Name of the marker file for starting a job. If you specify a marker file, the migration job is executed only when the marker file exists in the source path. The marker file will not be migrated. | ok.txt | |
Suspension Period | Waiting period for a marker file. If you set Start Job by Marker File to Yes but there is no marker file in the source path, the job fails when the suspension period times out. If you set this parameter to 0 and there is no marker file in the source path, the job will fail immediately. Unit: second | 10 | |
Filter Type | Only paths or files that meet the filtering conditions are transferred. The options are None, Wildcard, and Regex. For details, see Incremental File Migration. | None | |
Directory Filter | If you set Filter Type to Wildcard or Regex, enter a wildcard character to filter paths. The paths that meet the filtering condition are migrated. You can configure multiple paths separated by commas (,). NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | *input,*out | |
File Filter | If you set Filter Type to Wildcard or Regex, enter a wildcard character to filter paths. The files that meet the filtering condition are migrated. You can configure multiple files separated by commas (,). NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | *.csv | |
Time Filter | If you select Yes, files are transferred based on their modification time. | Yes | |
Minimum Timestamp | If you set Time Filter to Yes, you can specify a point in time for Minimum Timestamp, and then only the files modified at or after the specified time are transferred. The time format must be yyyy-MM-dd HH:mm:ss. This parameter can be set to a macro variable of date and time. For example, ${timestamp(dateformat(yyyy-MM-dd HH:mm:ss,-90,DAY))} indicates that only files generated within the latest 90 days are migrated. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | 2019-07-01 00:00:00 | |
Maximum Timestamp | If you set Time Filter to Yes, you can specify a point in time for Maximum Timestamp, and then only the files modified before the specified time are transferred. The time format must be yyyy-MM-dd HH:mm:ss. This parameter can be set to a macro variable of date and time. For example, ${timestamp(dateformat(yyyy-MM-dd HH:mm:ss))} indicates that only the files whose modification time is earlier than the current time are migrated. NOTE: If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). | 2019-07-30 00:00:00 | |
Disregard Non-existent Path or File | If this parameter is set to Yes, the job can be successfully executed even if the source path does not exist. | No | |
Marker File Type | This parameter is available only when Start Job by Marker File is set to Yes.
| MARK_DOING | |
Whether to skip empty lines | This parameter is available only when File Format is set to CSV. If a line is empty, it is skipped. | No | |
null value | This parameter is available only when File Format is set to Binary. No string can be used to define a null value in text files. This parameter specifies the string to be identified as a null value. | No | |
MD5 File Extension | This parameter is displayed only when File Format is set to Binary. This parameter is used to check whether the files extracted by CDM are consistent with source files. For details, see MD5 Verification. | .md5 |
