From HDFS
If the source link of a job is an HDFS link, that is, if data is exported from MRS HDFS, FusionInsight HDFS, or Apache HDFS, configure the source job parameters based on Table 1.
Category |
Parameter |
Description |
Example Value |
Basic parameters |
Source Link Name |
Select a type from the drop-down list box. |
hdfs_to_cdm |
Source Directory/File |
This parameter is available only when Pull List File is set to No. Directory or file path from which data will be extracted. Directory from which data is to be migrated. All files (including all nested subdirectories and their subfiles) in the directory will be migrated. This parameter can be configured as a macro variable of date and time and a path name can contain multiple macro variables. When the macro variable of date and time works with a scheduled job, the incremental data can be synchronized periodically. For details, see Incremental Synchronization Using the Macro Variables of Date and Time.
If you have configured a macro variable of date and time and schedule a CDM job through DataArts Studio DataArts Factory, the system replaces the macro variable of date and time with (Planned start time of the data development job – Offset) rather than (Actual start time of the CDM job – Offset). |
/user/cdm/ |
File Format |
File format used when transferring data. The options are as follows:
CSV |
Pull List File |
This parameter is displayed only when File Format is set to Binary.
If the pull list file function is enabled, the content of a file (such as a .txt file) in an OBS bucket can be read as the list of files to be migrated. The content in the file must be the absolute path of the file to be migrated (rather than a directory). The following is example content:
/mrs/job-properties/application_1634891604621_0014/job.properties /mrs/job-properties/application_1634891604621_0029/job.properties |
Yes |
OBS Link of List File |
This parameter is available only when Pull List File is set to Yes. You can select the OBS link where the list file is located. |
OBS_test_link |
OBS Bucket of entries files |
This parameter is available only when Pull List File is set to Yes. It indicates the name of the OBS bucket where the list file is located. |
01 |
Path/Directory of entries files |
This parameter is available only when Pull List File is set to Yes. It indicates the absolute path or directory of the list file in the OBS bucket. |
/0521/Lists.txt |
Advanced attributes |
Line Separator |
Lind feed character in a file. By default, the system automatically identifies \n, \r, and \r\n. This parameter is displayed only when File Format is set to CSV. |
\n |
Field Delimiter |
Character used to separate fields in the file. To set the Tab key as the delimiter, set this parameter to \t. This parameter is displayed only when File Format is set to CSV. |
Use First Row as Header |
This parameter is displayed only when File Format is set to CSV. When you migrate a CSV file to a table, CDM writes all data to the table by default. If you set this parameter to Yes, CDM uses the first N rows of the CSV file as the heading row and does not write the row to the destination table. |
No |
Encoding Type |
Encoding type, for example, UTF-8 or GBK. You can set the encoding type for text files only. This parameter is invalid when File Format is set to Binary. |
GBK |
Start Job by Marker File |
Whether to start a job by a marker file. A job is only started if there is a marker file for starting the job in the source path. If there is no marker file, the job will be suspended for a period of time specified by Suspension Period. |
ok.txt |
Filter Type |
Only paths or files that meet the filtering conditions are transferred. The options are None, Wildcard, and Regex. For details, see Incremental File Migration. |
Directory Filter |
If you set Filter Type to Wildcard or Regex, enter a wildcard character to filter paths. The paths that meet the filtering condition are migrated. You can configure multiple paths separated by commas (,).
*input |
File Filter |
If you set Filter Type to Wildcard or Regex, you can enter a wildcard character to search for files in a specified path. The files that meet the search criteria are migrated. You can configure multiple files separated by commas (,).
*.csv |
Time Filter |
If you select Yes, files are transferred based on their modification time. |
Yes |
Minimum Timestamp |
If you set Filter Type to Time Filter, and specify a point in time for this parameter, only the files modified at or after the specified time are transferred. The time format must be yyyy-MM-dd HH:mm:ss. This parameter can be set to a macro variable of date and time. For example, ${timestamp(dateformat(yyyy-MM-dd HH:mm:ss,-90,DAY))} indicates that only files generated within the latest 90 days are migrated.
2019-07-01 00:00:00 |
Maximum Timestamp |
If you set Filter Type to Time Filter, and specify a point in time for this parameter, only the files modified before the specified time are transferred. The time format must be yyyy-MM-dd HH:mm:ss. This parameter can be set to a macro variable of date and time. For example, ${timestamp(dateformat(yyyy-MM-dd HH:mm:ss))} indicates that only the files whose modification time is earlier than the current time are migrated.
2019-07-30 00:00:00 |
Create Snapshot |
If you set this parameter to Yes, CDM creates a snapshot for the source directory to be migrated (the snapshot cannot be created for a single file) before it reads files from HDFS. Then CDM migrates the data in the snapshot. Only the HDFS administrator can create a snapshot. After the CDM job is completed, the snapshot is deleted. |
No |
Encryption |
If the source data is encrypted, CDM can decrypt the data before exporting it. Select whether to decrypt the source data and select a decryption algorithm. The options are as follows:
For details, see Encryption and Decryption During File Migration. |
AES-256-GCM |
DEK |
This parameter is displayed only when Encryption is set to AES-256-GCM. The key consists of 64 hexadecimal numbers and must be the same as the DEK configured during encryption. If the encryption and decryption keys are inconsistent, the system does not report an exception, but the decrypted data is incorrect. |
DD0AE00DFECD78BF051BCFDA25BD4E320DB0A7AC75A1F3FC3D3C56A457DCDC1B |
IV |
This parameter is displayed only when Encryption is set to AES-256-GCM. The initialization vector consists of 32 hexadecimal numbers and must be the same as the IV configured during encryption. If the encryption and decryption keys are inconsistent, the system does not report an exception, but the decrypted data is incorrect. |
5C91687BA886EDCD12ACBC3FF19A3C3F |
MD5 File Extension |
This parameter is displayed only when File Format is set to Binary. This parameter is used to check whether the files extracted by CDM are consistent with source files. For details, see MD5 Verification. |
.md5 |
