CloudTable OpenTSDB Link Parameters
When connecting CDM to CloudTable OpenTSDB, configure the parameters as described in Table 1.
| Parameter | Description | Example Value |
| Name | Link name, which should be defined based on the data source type, so it is easier to remember what the link is for | TSDB_link |
| OpenTSDB Link | ZK link of OpenTSDB | opentsdb-sp8afz7bgbps5ur.cloudtable.com:4242 |
| Security Mode | Security or non-security mode If you select Security, enter the project ID, username, and AK/SK. | Nonsecurity |
| Project ID | Project ID in the region where CloudTable resides
       A project is a group of tenant resources, and an account ID corresponds to the current account. The IAM ID corresponds to the current user. You can view the project IDs, account IDs, and user IDs in different regions on the corresponding pages.
| Username | Username for accessing CloudTable | admin |
| AK | AK and SK for accessing CloudTable. You need to create an access key for the current account and obtain an AK/SK pair.
| SK | - |
