CSS Link Parameters
Huawei Cloud Cloud Search Service (CSS) is a fully hosted distributed search service powered by open-source Elasticsearch. CSS links can be used to migrate log files and database records to CSS for search and analysis using Elasticsearch.
- You are advised to use Logstash to import data to CSS. For details, see Using Logstash to Import Data to Elasticsearch.
- Do not change the password or user when the job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 lists the parameters for a CSS link.
Parameter |
Description |
Example Value |
Name |
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for |
css_link |
Elasticsearch Server List |
IP addresses or domain names (including the port numbers) of one or more Elasticsearch servers. The format is ip:port. Use semicolons (;) to separate multiple IP addresses. |
192.168.0.1:9200;192.168.0.2:9200 |
Security Mode Authentication |
Whether to enable security mode. If Security Mode has been enabled for the CSS cluster to be connected, set this parameter to Yes. Otherwise, set this to No. |
Yes |
Username |
This parameter is displayed when Security Mode Authentication is set to Yes. It indicates the username used for connecting to CSS. |
admin |
Password |
This parameter is displayed when Security Mode Authentication is set to Yes. It indicates the password used for connecting to CSS. |
HTTPS Access |
This parameter is displayed when Security Mode Authentication is set to Yes. This parameter specifies whether to enable HTTPS access. HTTPS access is more secure than HTTP access. |
Yes |
