Updated on 2025-04-09 GMT+08:00
DDS Link Parameters
The DDS link is used to synchronize data from Document Database Service (DDS) on HUAWEI CLOUD to a big data platform.
When connecting CDM to DDS, configure the parameters as described in Table 1.
  • DDS data sources with SSL enabled are not supported.
  • Do not change the password or user when a job is running. If you do so, the password will not take effect immediately and the job will fail.
Table 1 DDS link parameters
Example Value
Name
Link name, which should be defined based on the data source type, so it is easier to remember what the link is for
dds_link
Server List
List of server addresses. Enter each address in the format of IP address or domain name of the database server:port number, and separate the entered addresses with semicolons (;).
192.168.0.1:7300;192.168.0.2:7301
Database Name
Name of the DDS database to be connected
DB_dds
Username
Username used for logging in to DDS
cdm
Password
Password used for logging in to DDS
Is direct connection mode
This mode applies to the scenario where the network of the primary node is normal but that of the replica node is abnormal.
  • Only one IP address can be configured for the server list in direct connection mode.
  • This mode applies to the scenario where the network of the primary node is normal but the network of the replica node is abnormal.
No
