Updated on 2025-07-25 GMT+08:00
Downloading CDM Cluster Logs
This section describes how to obtain cluster logs to view the job running history and locate job failure causes.
You have created a CDM cluster.
  1. Log in to the CDM console and choose Cluster Management in the left navigation pane.
    Another method: Log in to the DataArts Studio console by following the instructions in Accessing the DataArts Studio Instance Console. On the DataArts Studio console, locate a workspace and click DataArts Migration to access the CDM console.
    Figure 1 Cluster list
    The Source column is displayed only when you access the DataArts Migration page from the DataArts Studio console.
  1. Locate the row that contains a cluster, click More in the Operation column, and select Download Log from the drop-down list.
    Figure 2 Download Log
  2. In the displayed dialog box, click OK to download logs to a local PC.
