Help Center/ Cloud Trace Service/ User Guide/ Data Trackers/ Disabling or Enabling a Tracker
Updated on 2025-02-27 GMT+08:00
You can disable a tracker on the CTS console. After a tracker is disabled, it will stop recording operations, but you can still view operation records that have been collected.
After a tracker is disabled, traces can still be reported to CTS. You can view traces of the last seven days in the trace list. However, new traces recorded after you disable the tracker cannot be viewed and transferred to OBS or LTS, and key event notifications will not be sent.
You have created a data tracker on the CTS console.
Disabling or Enabling a Data Tracker
  2. Click in the upper left corner to select the desired region and project.
  3. Click in the upper left corner and choose Management & Governance > Cloud Trace Service. The CTS console is displayed.
  4. Choose Tracker List in the navigation pane.
  5. Click Disable in the Operation column in the row of the target data tracker.
    Figure 1 Disabling a tracker
  6. Click OK. After the tracker is disabled, the Disable button changes to Enable.
  7. To enable the tracker, click Enable and then click OK. The tracker will start recording operations again.
