- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
Creating a Tracker
You can create data trackers to log operations on data. Data trackers record data traces, that is, logs of tenant operations (such as upload and download) on data in OBS buckets.
When you enable CTS, a management tracker is created automatically. Only one management tracker can be created. The trackers you created are all data trackers.
- CTS records operations performed in the last seven days. To store traces for a longer time, configure your tracker. The tracker will continuously store traces to your specified LTS log stream or OBS bucket.
You have enabled CTS. For details, see Overview.
Creating a Data Tracker
- In the service list, choose Management & Governance > Cloud Trace Service. The CTS console is displayed.
- Choose Tracker List in the navigation pane. In the upper right corner of the displayed page, click Create Tracker.
- Set basic information. Enter a tracker name. Click Next.
A data tracker name contains only letters, digits, hyphens (-), and underscores (_), and must start with a letter or digit. It cannot be empty and contains up to 32 characters. Do not use system or system-trace as a data tracker name.
- Select a trace. Set parameters and click Next.
Table 1 Parameters for selecting a trace Parameter
Data Trace Source
Container for storing data traces. Currently, OBS buckets are used.
OBS Bucket
Select an OBS bucket from the drop-down list.
Operation
- Select the operations to record.
- Options: Read and Write. Select at least one of them.
- Configure a transfer. Set parameters and click Next. You can only query operation records of the last seven days on the CTS console. To store and query operation records beyond seven days, transfer them to OBS or LTS. For details, see Table 2 and Table 3.
Table 2 Parameters for configuring the transfer to OBS Parameter
Transfer to OBS
If you select Yes, select an existing OBS bucket or create one on the Configure Tracker page and set File Prefix.
When Transfer to OBS is disabled, no operation is required.
Create a cloud service agency.
(Mandatory) If you select this check box, CTS automatically creates a cloud service agency when you create a tracker. The agency authorizes you to use OBS.
OBS Bucket
New: An OBS bucket will be created automatically with the name you enter.
The OBS bucket created on this page is a single-AZ private bucket with Standard storage. If you need other configurations, create the bucket on OBS Console in advance and choose Existing to select it.
Existing: Select an existing OBS bucket in the current region.
Select Bucket
When you select New, enter an OBS bucket name. The OBS bucket name cannot be empty. It can contain 3 to 63 characters, including only lowercase letters, digits, hyphens (-), and periods (.). It cannot contain two consecutive periods (for example, my..bucket). A period (.) and a hyphen (-) cannot be adjacent to each other (for example, my-.bucket and my.-bucket). Do not use an IP address as a bucket name.
If you select Existing for OBS Bucket, select an existing OBS bucket.
Retention Period
The duration for storing traces in the OBS bucket. This configuration will apply to the selected bucket and all files in it. Different compliance standards require different trace retention periods. You are advised to set the retention period to at least 180 days.- For a data tracker, you can set the duration to 30 days, 60 days, 90 days, 180 days, 3 years, or the same as that of OBS.
File Prefix
A file prefix is used to mark transferred trace files. The prefix you set will be automatically added to the beginning of the file names, facilitating file filtering. Enter 0 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Compression
The usage of object storage space can be reduced.- Do not compress: Transfer files in the *.json format.
- gzip: Transfer files in *.json.gz format.
Sort by Cloud Service
- When this function is enabled, the cloud service name is added to the transfer file path, and multiple small files are generated in OBS. Example: /CloutTrace/cn-north-7/2022/11/8/doctest/Cloud service/_XXX.json.gz
- When this function is disabled, the cloud service name will not be added to the transfer file path. Example: /CloutTrace/cn-north-7/2022/11/8/doctest/_XXX.json.gz
Transfer Path
Log transfer path is automatically set by the system.
Verify Trace File
When this function is enabled, integrity verification will be performed to check whether trace files in OBS buckets have been tampered with. For details about file integrity verification, see Verifying Trace File Integrity.
Table 3 Parameters for configuring the transfer to LTS Parameter
Transfer to LTS
When Transfer to LTS is enabled, traces are transferred to the log stream.
Log Group
When Transfer to LTS is enabled, the default log group name CTS is set. When Transfer to LTS is disabled, no operation is required.
- Preview the tracker information and click Create.
- Click OK.
