- What's New
- Function Overview
- Getting Started
- User Guide
- Best Practices
- API Reference
- SDK Reference
- Must I Use an IAM User (Sub Account) to Configure Transfer on CTS and Perform Operations on an OBS Bucket?
- What Information Is on the Trace List?
- How Will CTS Be Affected If My Account Balance Is Insufficient?
- What Are the Recommended Users of CTS?
- What Will Happen If I Have Enabled Trace Transfer But Have Not Configured an Appropriate Policy for an OBS Bucket?
- Does CTS Support Integrity Verification of Trace Files?
- Why Are There Some Null Fields on the View Trace Page?
- Why Is an Operation Recorded Twice in the Trace List?
- What Services Are Supported by Key Event Notifications?
- How Can I Store Trace Files for a Long Time?
- Why Are user and source_ip Null for Some Traces with trace_type as SystemAction?
- How Do I Find Out Who Created a Specific ECS?
- How Do I Find Out the Login IP Address of an IAM User?
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS in Pay-per-Use or Yearly/Monthly?
- What If I Cannot Query Traces?
- Can I Disable CTS?
- How Do I Make the Log Retention Period 180 Days?
- What Can I Do If a Tracker Cannot Be Created on the CTS Console?
- What Should I Do If I Cannot Enable CTS as an IAM User?
- How Do I Enable Alarm Notifications for EVS?
- Can I Receive Duplicate Traces?
- What Should I Do If I Fail to Transfer Data to an OBS Bucket Authorized by a Key of Another Tenant?
- Does the cts_admin_trust Agency Include OBS Authorization?
- Does CTS Record ECS Creation Failures?
- Glossary
More Documents
- Getting Started
- Querying Traces
- Management Trackers
- Data Trackers
- Application Examples
- Trace References
- Cross-Tenant Transfer Authorization
- Verifying Trace File Integrity
- Auditing
- Permissions Management
- Supported Services and Operations
- Why Are Two deleteMetadata Traces Generated When I Buy an ECS?
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris)
- Getting Started
- Querying Traces
- Trace References
- Auditing
- API Reference (Paris)
- Getting Started
- Querying Traces
- Trackers
- Organization Trackers
- Trace References
- Auditing
- API Reference (Kuala Lumpur Region)
- Videos
Querying Transferred Traces
CTS periodically sends trace files to OBS buckets. A trace file is a collection of traces. CTS generates trace files based on services and transfer cycle, and adjusts the number of traces contained in each trace file as needed. CTS can also save audit logs to LTS log streams.
This section describes how to view historical operation records in trace files downloaded from OBS buckets and in LTS log streams.
For global services, you must configure trackers on the CTS console in the central region (CN-Hong Kong). This configuration enables the function of transferring traces to OBS or LTS. This function will not take effect if you perform the configuration on the CTS console in any region outside the central region.
For details about Huawei Cloud global services, see Notes and Constraints.
You have configured a tracker in CTS and enabled Transfer to OBS or Transfer to LTS. For details about how to configure a transfer, see Configuring a Tracker.
Querying Traces Transferred to OBS
If you enable Transfer to OBS when configuring the tracker, traces will be periodically transferred to a specified OBS bucket as trace files for long-term storage.
- Click
in the upper left corner and choose Management & Governance > Cloud Trace Service. The CTS console is displayed.
- Choose Tracker List in the navigation pane.
- Click a bucket in the OBS Bucket column.
Figure 1 Selecting an OBS bucket
- In the OBS bucket, locate the file storage path to view the desired trace, and click Download on the right to download the file to the default download path of the browser. If you need to save it to a custom path, click More > Download As on the right.
- The trace file storage path is as follows:
OBS bucket name/CloudTraces/Region/Year/Month/Day/Tracker name/Cloud service
Example: User-defined name/CloudTraces/ap-southeast-1/2016/5/19/system/ECS
- The trace file naming format is as follows:
Trace file prefix_CloudTrace_Region/Region-project_Time when the trace file was uploaded to OBS: Year-Month-DayTHour-Minute-SecondZ_Random characters.json.gz
Example: FilePrefix_CloudTrace_ap-southeast-1_2024-12-13T01-29-19Z_47b9d51830deff47.json.gz
- The OBS bucket name and trace file prefix are set by you and other parameters are automatically generated.
- File download will incur request fees and traffic fees.
- If you disable Sort by Cloud Service when configuring a tracker to transfer traces to OBS, the cloud service will not be displayed in the transfer path. Example: User-defined name/CloudTraces/Region/2016/5/19/system
For details about key fields in the CTS trace structure, see Trace Structure and Example Traces.
Figure 2 Viewing trace file content - The trace file storage path is as follows:
- Decompress the downloaded package to obtain a JSON file with the same name as the package, as shown in Figure 3. Open the JSON file using a text file editor to view traces.
Querying Traces Transferred to LTS
If you enable Transfer to LTS when configuring a tracker, traces will be transferred to the CTS/{Tracker Name} log stream for long-term storage. {Tracker Name} indicates the name of the current tracker. For example, the log stream path of the management tracker is CTS/system-trace.
- Click
- Click an LTS log stream in the Storage column.
Figure 4 Selecting an LTS log stream
- On the Log Stream tab page in the CTS log group page, select the {Tracker name} log stream to view trace logs.
- Click
to download the log file to your local PC. Each time you can download up to 5,000 log events. If the number of selected log events exceeds 5,000, you cannot download them directly from LTS. Transfer them to OBS and then download them from OBS.
