Before You Start
To use CSE, ensure that the following conditions are met:
- You have registered a HUAWEI ID and enabled Huawei Cloud services.
- The current login account has been authorized to use CSE. For details, see Using IAM to Grant Access to CSE.
CSE needs the Virtual Private Cloud (VPC) and Domain Name Service (DNS) services to run. If you have not granted any permissions, create a cloud service agency to grant permissions to CSE. That is, click OK in the Grant Permissions to CSE dialog box. CSE will create an agency named cse_admin_trust on IAM. Go to the agency list to view the details. You must have the Security Administrator role. Without permissions, some CSE functions will be affected, including engine creation and upgrade and security authentication enabling/disabling.
