Updated on 2025-08-29 GMT+08:00
Viewing Nacos Engine Information
This section describes how to view details about a Nacos instance on the CSE console.
Video Tutorial
This video shows how to view details and parameters of a registry/configuration center.
  1. In the left navigation pane, choose Registry/Configuration Center.
  2. Click the target Nacos instance. You can click an Available instance to go to the Basic Information page.
  3. View the Nacos engine information shown in Table 1.
    Table 1 Engine details
    Type
    Basic Information
    Name
    Engine name entered when Creating a Nacos Engine. Click to copy it. An engine name can be changed. The name contains 3 to 24 characters, including letters, digits, and hyphens (-), and starts with a letter but cannot end with a hyphen.
    ID
    Engine ID. Click to copy it.
    Running Status
    Engine status.
    Registry/Configuration Center Instance
    Select Nacos.
    Version
    Engine version.
    Capacity Specifications
    Engine specifications selected when Creating a Nacos Engine. If the engine is a small-scale engine, click Change Specifications on the right to expand the capacity. For details, see Increasing Nacos Engines.
    Enterprise Project
    Enterprise project selected when Creating a Nacos Engine.
    Billing Mode
    Billing mode selected in Creating a Nacos Engine. Only pay-per-use billing is supported.
    Created
    Time when Creating a Nacos Engine.
    Connection Information
    Private IP
    Private address of a Nacos engine.
    Private Port
    Internal port of a Nacos engine.
    VPC selected when you create a registry/configuration center.
    Subnet
    Subnet selected when you create a registry/configuration center.
    Whitelist Access
    Nacos supports whitelist control. Multiple IP addresses or IP address segments can be configured. IP addresses that are not in the IP address segments cannot be accessed. For details about whitelist access, see Managing the Nacos Engine Whitelist.
    More Settings
    Tag
    Tags added to the Nacos engine. You can also click Tag Management and perform operations on tags as required. For details, see Managing Nacos Engine Tags.
