Updated on 2026-07-13 GMT+08:00
Creating a Nacos Engine
Nacos engines resolve the pain points of registration discovery and configuration management in the microservice architecture and provide lightweight service governance capabilities. You can create a CSE Nacos engine on the console with just a few clicks, reducing O&M costs and allowing you to focus on your services. This section describes how to create an engine whose registry/configuration center is Nacos.
  • Cluster nodes in the registry/configuration center are evenly distributed to different AZs. A failure of a single node does not affect external services.
  • Currently, Nacos engines cannot be purchased. To purchase them, submit a service ticket to contact technical support to obtain the purchase permission.
  • You may fail in buying an engine for insufficient underlying resources. To prevent this, delete engines in time so that you will not be charged if your engines restore upon sufficient underlying resources.
  • By default, a maximum of five Nacos engines can be created for each project. Nacos engines share quotas (five engines) with ServiceComb engines. If you want to create more, submit a service ticket to increase the quota. For details about projects, see Projects.
  • You cannot use a shared VPC to create a Nacos engine. Otherwise, the engine fails to be created.
  • The VPC cannot be changed once the Nacos engine is created.
  • The login account has the permission to create a microservice engine. For details, see Using IAM to Grant Access to CSE.
  • A Nacos engine runs on a VPC. Before creating a Nacos engine, ensure that VPCs and subnets are available. For details, see Creating a VPC with a Subnet.
  • The user has the CSE FullAccess and DNS Full Access permissions.
Video Tutorial
This video shows how to create a registry/configuration center.
As product functions evolve, the GUI may vary. This video is for reference only.
Creating a Registry/Configuration Center
  1. Go to the Buy Registry/Configuration Center Instance page.
  2. Set parameters according to the following table. Parameters marked with an asterisk (*) are mandatory.
    *Billing Mode
    Billing mode. Currently, Pay-per-use is supported. Pay-per-use is postpaid and useful if you do not want upfront payments or long-term commitments.
    *Enterprise Project
    Select the project where the Nacos engine is located. You can search for and select the required enterprise project from the drop-down list.
    Enterprise projects let you manage cloud resources and users by project.
    An enterprise project can be used after it is created and enabled. For details, see Enabling and Accessing Enterprise Management. By default, default is selected.
    After a registry/configuration center Nacos engine is created, you can remove Nacos engine resources out of the current enterprise project and into a new enterprise project. For details, see Removing Resources from an Enterprise Project and Adding Resources to an Enterprise Project.
    *Name
    Enter a Nacos engine name. The name contains 3 to 24 characters, including letters, digits, and hyphens (-), and starts with a letter but cannot end with a hyphen (-). The name cannot be default.
    *Registry/Configuration Center Instance
    Select Nacos.
    *Instances
    Select the required capacity specifications. For details about the specifications, see Specifications.
    Version
    Only the latest version can be created.
    *Network
    Select a VPC and subnet to provision logically isolated, configurable, and manageable virtual networks for your engine.
    • To use a created VPC, search for and select a VPC created under the current account from the drop-down list.
    • To use a new VPC, create one on the VPC console. For details, see Creating a VPC with a Subnet.
    Tag
    Tags are used to identify cloud resources. When you have multiple cloud resources of the same type, you can use tags to classify them based on usage, owner, or environment.
    Click Add Tag. In the Add Tag dialog box, enter a tag key and value. For details about tag naming rules, see Managing Tags. In the Add Tag dialog box, you can click Add Tag to add multiple tags at a time, or click next to a tag to delete the tag.
  3. Click Buy. The page for confirming the engine information is displayed.
  4. Click Submit. When the status becomes Available, the engine is created.
