CPH Metrics
This section describes the namespace, metrics, and dimensions reported by CPH to Cloud Eye. You can log in to the Cloud Eye console or call Cloud Eye APIs to query the metrics and alarms generated for CPH.
Cloud Eye can monitor dimensions (or objects) nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level. For example, if the monitored dimension of a metric is instance_id,cph_id, instance_id indicates level 0 and cph_id indicates level 1.
Namespace
SYS.CPH
Metrics
CPH supports the following metrics: cloud phone server metrics (Table 1), cloud phone metrics (Table 2), disk metrics (Table 3), and GPU metrics (Table 4).
| Metric ID | Metric | Description | Value Range | Unit | Conversion Rule | Dimension | Monitoring Period (Raw Data) |
| cpu_usage | CPU Usage | CPU usage of the monitored server | 0-100 | % | N/A | instance_id | 1 minute |
| load_average5 | 5-Minute Avg. Load | CPU load averaged for the last 5 minutes for the monitored server | ≥ 0 | N/A | N/A | instance_id | 1 minute |
| mem_usedPercent | Memory Usage | Memory usage of the monitored server | 0-100 | % | N/A | instance_id | 1 minute |
| net_rx | Network Rate (Incoming) | Bytes/second received by all NICs of the monitored server | ≥ 0 | Byte/s | 1024 (IEC) | instance_id | 1 minute |
| net_tx | Network Rate (Outgoing) | Bytes/second sent by all NICs of the monitored server | ≥ 0 | Byte/s | 1024 (IEC) | instance_id | 1 minute |
| cph_sharebase_usedPercent | Shared Storage Usage | Shared storage used by the monitored server | 0-100 | % | N/A | instance_id | 1 minute |
| cph_sharebase_available | Available Shared Storage | Available shared storage of the monitored server | - | Byte | 1024 (IEC) | instance_id | 1 minute |
| cph_cpu_usage | CPU Usage | Cloud phone CPU usage | 0-100 | % | N/A | instance_id,cph_id | 1 minute |
| cph_mem_usedPercent | Memory Usage | Cloud phone memory usage (%) | 0-100 | % | N/A | instance_id,cph_id | 1 minute |
| cph_mem_used | Memory Used | Cloud phone memory used (bytes) | > 0 | Byte | 1024 (IEC) | instance_id,cph_id | 1 minute |
| cph_net_rx | Network Rate (Incoming) | Bytes/second received by the cloud phone NIC | ≥ 0 | Byte/s | 1024 (IEC) | instance_id,cph_id | 1 minute |
| cph_net_tx | Network Rate (Outgoing) | Bytes/second sent by the cloud phone NIC | ≥ 0 | Byte/s | 1024 (IEC) | instance_id,cph_id | 1 minute |
| cph_disk_agt_read_bytes_rate | I/O Read Rate | Bytes read from the cloud phone per second | ≥ 0 | Byte/s | 1024 (IEC) | instance_id,cph_id | 1 minute |
| cph_disk_agt_write_bytes_rate | I/O Write Rate | Bytes written to the cloud phone per second | ≥ 0 | Byte/s | 1024 (IEC) | instance_id,cph_id | 1 minute |
| cph_disk_percent | Data Disk Usage | Data disk usage of the cloud phone | 0-100 | % | N/A | instance_id,cph_id | 1 minute |
| cph_disk_inode_percent | Data Disk inode Usage | Data disk inode usage of the cloud phone | 0-100 | % | N/A | instance_id,cph_id | 1 minute |
| cph_sysdisk_percent | System Disk Usage | System disk usage of the cloud phone | 0-100 | % | N/A | instance_id,cph_id | 1 minute |
| cph_sysdisk_inode_percent | System Disk inode Usage | System inode disk usage of the cloud phone | 0-100 | % | N/A | instance_id,cph_id | 1 minute |
| cph_gpu_mem | GPU Memory Size | Total GPU memory size of the cloud phone | ≥0 | MB | 1024 (IEC) | instance_id,cph_id | 1 minute |
| disk_usage_read_request_rate | Disk Read IOPS | Read requests/second sent to the monitored disk | ≥ 0 | r/s | N/A | instance_id,disk_name | 1 minute |
| disk_usage_write_request_rate | Disk Write IOPS | Write requests/second sent to the monitored disk per second | ≥ 0 | w/s | N/A | instance_id,disk_name | 1 minute |
| disk_usage_read_rate | Disk Read Bandwidth | Number of bytes read from the monitored object per second | ≥ 0 | KB/s | N/A | instance_id,disk_name | 1 minute |
| disk_usage_write_rate | Disk Write Bandwidth | Number of bytes written to the monitored object per second | ≥ 0 | KB/s | N/A | instance_id,disk_name | 1 minute |
| disk_usage_read_await | Disk Read Await | Average wait time per I/O read for the monitored disk in the monitoring period | ≥ 0 | ms | N/A | instance_id,disk_name | 1 minute |
| disk_usage_write_await | Disk Write Await | Average wait time per I/O write for the monitored disk in the monitoring period | ≥ 0 | ms | N/A | instance_id,disk_name | 1 minute |
| disk_usage_util | Disk I/O Utilization | Percentage of time spent during which read and write requests were sent to the monitored disk in the monitoring period | 0-100 | % | N/A | instance_id,disk_name | 1 minute |
| gpu_usage_gpu_load | GPU Usage | GPU usage of the monitored video card on the server | 0-100 | % | N/A | instance_id,gpu_index | 1 minute |
| gpu_usage_vram | GPU VRAM Usage | GPU VRAM usage of the monitored video card on the server | 0-100 | % | N/A | instance_id,gpu_index | 1 minute |
| gpu_usage_gtt | GPU GTT Usage | GPU GTT usage of the monitored video card on the server | 0-100 | % | N/A | instance_id,gpu_index | 1 minute |
| gpu_usage_power | GPU Power | GPU power of the monitored video card on the server | > 0 | W | N/A | instance_id,gpu_index | 1 minute |
| gpu_usage_temperature | GPU Temperature | GPU temperature of the monitored video card on the server | > 0 | °C | N/A | instance_id,gpu_index | 1 minute |
| gpu_usage_status | GPU Status | GPU status of the monitored video card on the server | N/A | N/A | N/A | instance_id,gpu_index | 1 minute |
| gpu_mem_busy_percent | GPU Memory Load | GPU memory load of the cloud phone | 0-100 | % | N/A | instance_id,gpu_index | 1 minute |
If an object is in a hierarchical system, specify the monitored dimension in hierarchical form when you use APIs to query metrics of this object.
For example, to query the CPU usage of a cloud phone on a server, the dimension should be instance_id,cph_id. instance_id is at level 0 and cph_id is at level 1.
- To query a single metric by calling an API, the cph_id dimension is used as follows:
dim.0=instance_id,1f40deafb8da456ab15d2fbcc70e43ee&dim.1=cph_id,7f0aa21f11864c04936ac61ba59f8c21
1f40deafb8da456ab15d2fbcc70e43ee and 7f0aa21f11864c04936ac61ba59f8c21 are dimension values of instance_id and cph_id, respectively. The values are examples only. For details about how to obtain the values, see Dimensions.
- To query multiple metrics by calling an API, the cph_id dimension is used as follows:
"dimensions": [ { "name": "instance_id", "value": "1f40deafb8da456ab15d2fbcc70e43ee" }, { "name": "cph_id", "value": "7f0aa21f11864c04936ac61ba59f8c21" } ]1f40deafb8da456ab15d2fbcc70e43ee and 7f0aa21f11864c04936ac61ba59f8c21 are dimension values of instance_id and cph_id, respectively. The values are examples only. For details about how to obtain the values, see Dimensions.
Dimensions
| Key | Value |
| instance_id | Cloud phone server ID Obtain the value by referring to Querying Cloud Phone Servers. |
| cph_id | Cloud phone ID Obtain the value by referring to Querying Cloud Phones. |
| disk_name | Disk name |
| gpu_index | GPU name |
