- What's New
- Billing
- Getting Started
User Guide
- Buying a Cloud Phone Server
- Accessing the Cloud Phone
- Cloud Phone Management
- Cloud Phone Server Management
Using AOSP
- Overview
- Automatic Application Authorization
- Loading Pictures
- Rooting
- Startup Script
- Automatic Installation of Applications
- Hiding Virtual Keys
- Hiding the Status Bar
- Disabling the Notification System
- Disabling Screenshot Protection
- Simulating Location Information
- App Installation Whitelist
- App Installation Blacklist
- Forcibly Installing a 32-Bit Application
- Dynamically Changing the System Language
- Background Process Management
- Texture Compression
- Restarting a Cloud Phone
- Device Emulation
- Cloud Phone Audio and Video
- Configuring a Route
- Permission Management
- Adjusting Resource Quotas
- Monitoring
- CTS
- Appendix
Best Practices
- Best Practices of Connecting to General-Purpose Cloud Phones
Best Practices of Cloud Phone Application Sharing
- Overview of Application Sharing
Usage Guide to Application Sharing
- Purchasing a Cloud Phone Server That Supports Application Sharing
- Preparing the TAR Package of an Application
- Pushing the TAR Package of an Application to a Cloud Phone Server
- Using the appctrl Command to Manage Shared Applications
- Deleting an Application
- Presetting Configuration Files by Sharing Applications
- appctrl Commands
- Installing an Application on Cloud Phones in Batches
- Modifying the Cloud Phone GPS Location
- Using the Cloud Phone Camera
- Using STF to Manage Cloud Phones in Batches
- Allowing a Cloud Phone Server to Access a Public Network Outside the Chinese Mainland
- Delegating CPH to Operate OBS Buckets
- Changing the AOSP Version of a Cloud Phone
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
Cloud Phone Server APIs
Cloud Phone Servers
- Querying cloud phone servers
- Querying the Details of a Cloud Phone Server
- Querying Flavors of Cloud Phone Servers
- Restarting Cloud Phone Servers
- Changing the Cloud Phone Server for a Cloud Phone
- Pushing Shared Storage Files
- Querying Shared Storage Files
- Deleting Shared Storage Files
- Pushing Shared Applications
- Deleting a Shared Application
- Changing the Flavor of a Cloud Phone Server
- Modifying the Name of a Cloud Phone Server
- Bandwidth
Cloud Phones
- Querying Cloud Phones
- Querying Cloud Phone Details
- Obtaining the Cloud Phone Access Information
- Querying Cloud Phone Flavors
- Querying the Image of a Cloud Phone
- Resetting Cloud Phones
- Restarting Cloud Phones
- Stopping Cloud Phones
- Editing the Name of a Cloud Phone
- Updating Properties of Cloud Phones
- Exporting Data from Cloud Phones
- Restoring Data of Cloud Phones
- Diverting Cloud Phone Traffic
- Expanding the Data Disk of a Cloud Phone
- Tasks
- Keys
- Encoding Services
- ADB Commands
- Tags
- Images
Cloud Phone Servers
- Common Parameters
- Appendix
Consulting
- What Are the Advantages of Huawei Cloud Phone Compared with Other Similar Solutions?
- Does Cloud Phone Support iOS?
- Are There Cloud Phone Root Permissions?
- Does Each Cloud Phone Has an Independent Public IP Address?
- How Is CPH Billed?
- How Do I Obtain the Project ID?
- How Do I Install Applications on a Cloud Phone?
- How Long Does It Take to Activate a Server After I Purchase It?
- What Should I Do If I Can't Find My Cloud Phone Server on the CPH Console?
- How Long Will Resources Be Released After My Cloud Phone Server Expires?
- What Can I Do If the Private Key File Is Lost?
- How Can I Know Whether the SSH Service Has Been Installed on My Local Device?
- What Are Common ADB Commands?
- Does the Cloud Phone Support Cameras?
- Does the Cloud Phone Support Facial Recognition?
- What Are the Security Group Authorization Rules for Cloud Phones Using Custom Networks?
SSH Tunnel Faults
- What Can I Do If the SSH Tunnel Fails to Be Established When I Access the Cloud Phone over the Public Network?
- What Does Message "Authorized users only. All activities may be monitored and reported." Indicate?
- What Can I Do If Message "too open" Is Displayed When I Am Establishing the SSH Tunnel?
- What Can I Do If Message "Permission denied" Is Displayed When I Am Establishing the SSH Tunnel?
- What Can I Do If Message "no match mac found" Is Displayed When I Am Establishing the SSH Tunnel?
- What Can I Do If Message "no matching key exchange method found" Is Displayed When I Am Establishing the SSH Tunnel?
- How Do I Keep an SSH Session Uninterrupted?
- What Can I Do If I Failed to Establish an SSH Tunnel?
- What Can I Do If an Error Occurs When I Invoke the Cloud Phone Query API?
- ADB Connection Faults
Consulting
On this page
This topic describes how to stop a cloud phone or multiple cloud phones on the CPH console.
- Before stopping a cloud phone, ensure that all files on it have been saved to prevent file loss.
- The cloud phone must be in the Running state. If the cloud phone is in other states, such as Faulty and Creating, it cannot be stopped.
- In the upper left corner, select the region where the target cloud phone is located.
- On the Service List page, choose Compute > Cloud Phone Host.
The CPH console is displayed.
- In the navigation pane on the left, choose Instances.
- In the cloud phone list,
- Locate the target cloud phone, click More in the Operation column, and choose Stop.
- Select multiple cloud phones and click Stop in the upper left corner of the list.
- In the right pane, click OK.
Figure 1 Stop confirmation
If the cloud phone enters the Stopping state, the cloud phone is stopped successfully.
Execution Result
The cloud phone enters the Stopped state.
Associated APIs
Parent topic: Cloud Phone Management
