Help Center/ CodeArts Build/ User Guide/ Configuring Project-Level Role Permissions
Updated on 2026-02-11 GMT+08:00
Assign a specific role to the new member. Each role comes with its own default permissions. For details, see Table 1.
Table 1 Default roles and permissions matrix for CodeArts Build
Role
Create
Edit
Delete
View
Execute
Clone
Disable
Assign Permissions
Group
Project creator
Project manager
Product manager
Test manager
Operation manager
System engineer
Committer
Developer
Tester
Participant
Viewer
Project admin
indicates that the roles have the permission, and indicates that they do not.
  • You have enabled CodeArts Build.
  • You have added members by referring to CodeArts User Guide > "Preparations" > "Adding Project Members", and assigned roles to the new members by referring to "Managing Permissions".
Accessing the CodeArts Build Homepage
  1. Log in to the Huawei Cloud console with your Huawei Cloud account.
  2. Click in the upper left corner and choose Developer Services > CodeArts Build from the service list.
  3. You can access CodeArts Build from either the homepage or the project page.
    • From the homepage
      Click Access Service to go to the CodeArts Build homepage, where you can find your build task list.
    • From the project page
      1. Click Access Service to see the CodeArts Build homepage.
      2. On the navigation bar, click Homepage.
      3. Click the name of the target project.
      4. Choose CICD > Build to view the build task list of the specified project.
Configuring Role Permissions
  1. Access the CodeArts Build homepage from the project page.
  2. In the navigation pane, choose Settings > Permissions.
  3. On the displayed page, assign appropriate permissions to define how each role can interact with CodeArts Build resources.
    Figure 1 Configuring project-level role permissions
For details about different roles' operation permissions on the specified build task, see Configuring Roles and Permissions.
Menu Icons and Their Usage on the CodeArts Build Homepage
CodeArts Build provides multiple choices of UI themes and layouts. This section walks you through the navigation bar that uses the Infinite theme and the Classic layout.
Table 2 Menu icons and their usage
Menu Icon
Click this icon to expand the drop-down list and select the region you want to switch to.
Data and resources are isolated between regions. Use your resources in the region where you purchased it.
Click this icon to expand the drop-down list and select Build to go to the CodeArts Build homepage, where you can find your build task list.
Click this project icon to expand the drop-down list and select the project you want to switch to when accessing CodeArts Build from the project page.
Click this icon to expand the drop-down list and select the desired item to manage custom templates, custom build environments, files, recycle bin, or pools.
Click this icon to run a build task.
Click this icon to favorite a build task.
Click this icon to expand the drop-down list and select the desired action to edit, clone, disable, or delete a build task.
