On this page
Building with HarmonyOS
Updated on 2025-01-03 GMT+08:00
Build, test, and deploy a project with Hvigor.
To build with Hvigor, the executor needs to have at least 4 vCPUs and 8 GB of memory, or higher.
Build on GUI
Add Build with HarmonyOS, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with HarmonyOS
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Currently, the default version HarmonyOS-API9 is supported.
Commands
Configure commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - harmonyos:
        inputs:
            command: |
                npm config set strict-ssl false
                npm config set registry=https://repo.huaweicloud.com/repository/npm/
                npm config set @ohos:registry=https://repo.harmonyos.com/npm/
                chmod +x hvigorw
                ./hvigorw clean assembleApp --no-daemon
           ignore_fail: true
Table 2 Parameters in the sample code
Type
command
String
Configure the HarmonyOS commands.
ignore_fail
string
Whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
