Generating a Unit Test Report
The Unit Test Report action generates a visualized report by parsing the unit test result file that you have generated. (This action is available only on the GUI.)
Currently, this action is only available in the ME-Riyadh region.
A unit test file cannot exceed 10 MB in size.
Before running the Unit Test Report action, ensure that the test result file has been generated and the file framework is supported by CodeArts Build.
Build on GUI
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Test Report Path | Specify the storage location for the test coverage report. Use a relative path from the project's root directory. For example, target/surefire-reports/TEST*.xml. Wildcard characters (* and **) can be used in the path for multi-level directory matching. |
| Release Test Coverage Report | You can configure whether to release a unit test coverage report as part of your build process. These reports provide visibility into which portions of the codebase are exercised by unit tests and which remain untested.
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
