On this page
Building with Flutter
Updated on 2024-11-21 GMT+08:00
Build Android applications with Flutter.
Build on GUI
Add Build with Flutter, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with Flutter
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Flutter
Select a Flutter version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
JDK
Select a JDK version that matches your current development environment.
NDK
Select an NDK version that matches your current development environment.
Commands
Configure the Flutter commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the Flutter official website.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - flutter:
       inputs:
          flutter: '1.17.5'
          jdk: '3333'
          ndk: '23.1.7779620'
          command: ./instrumented.apk
          ignore_fail: true
Table 2 Parameters in the sample code
Type
flutter
String
jdk
String
ndk
String
command
String
Configure the Flutter commands. For more commands, see the Flutter official website.
ignore_fail
String
Whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
