On this page
Building with Grails
Updated on 2024-11-21 GMT+08:00
Build a web application with Grails.
Build on GUI
Add Build with Grails, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with Grails
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Configure the Grails commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the Grails official website.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
3
4
5
6
7
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - grails:
       inputs:
          command: grails war
          ignore_fail: true
Table 2 Parameters in the sample code
Type
command
String
Configure the Grails commands. For more commands, see the Grails official website.
ignore_fail
String
Whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
