Updated on 2026-07-29 GMT+08:00
Building Android App with Ionic
In this action, you build an Ionic Android app, which is a mobile app that works across multiple platforms. This action allows you to quickly develop mobile apps, mobile web pages, hybrid apps, and web pages.
The project contains the project compilation description files such as ionic.config.json, package.json, and angular.json.
Build on GUI
Add Build Android App with Ionic, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building an Android app with Ionic
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Gradle
Select a Gradle version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
JDK
Select a JDK version that matches your current development environment.
NDK
Select an NDK version that matches your current development environment.
Commands
Configure the packaging script in the command box. For more commands, see the Ionic official website.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - ionic_android_app:
       inputs:
          gradle: '4.8'
          jdk: '33'
          ndk: '17'
          command: ./instrumented.apk
          ignore_fail: true
Table 2 Parameters in the sample code
Type
gradle
String
jdk
String
ndk
String
command
String
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
