Updated on 2026-07-29 GMT+08:00
Building with Go
In this action, you build a project with the Go language. This involves compiling the source code to produce executables, managing project dependencies, and customizing the build process.
Build on GUI
Add Build with Go, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with Go
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Configure the Go project build command, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the Go official website.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - go:
        inputs:
          command: |
            export GO15VENDOREXPERIMENT=1
            export GOPROXY=https://goproxy.cn
            mkdir -p $GOPATH/src/example.com/demo/
            cp -rf . $GOPATH/src/example.com/demo/
            go install example.com/demo
            cp -rf $GOPATH/bin/ ./bin
          ignore_fail: true
Table 2 Parameters in the sample code
Type
command
String
Configure the command for building a Go project. For more commands, see the Go official website.
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
