Updated on 2026-07-29 GMT+08:00
Building with PyInstaller
Use PyInstaller to package Python scripts into standalone executables.
Build on GUI
Add Build with PyInstaller, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with PyInstaller
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Configure the build and packaging commands or use the default commands, which will package the project into an executable. For more commands, see the PyInstaller official website.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - python:
        name: Build with PyInstaller
        image: cloudbuild@python3.6
        inputs:
          command: |
            pip config set global.index-url https://pypi.org/simple
            pip config set global.trusted-host repo.xxcloud.com
            # Create a single executable file in the dist directory with -F.
            # For command details, see https://pyinstaller.readthedocs.io/en/stable/usage.html.
            pyinstaller -F  *.py
          ignore_fail: true
Table 2 Parameters in the sample code
Type
name
String
Optional.
String
Optional.
Enter the image version, which should include the fixed part cloudbuild@ and the supported Python version following it.
The default value is cloudbuild@python3.6.
command
String
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
