Building with Setuptools
Use Setuptools to package Python applications.
When using Setuptools to pack the code, ensure that the setup.py file exists in the root directory of the code. For details on how to write the setup file, see the official instructions of Python.
Build on GUI
Add Build with Setuptools, when configuring build actions. Set the parameters according to Table 1.
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Tool Version | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| Commands | Configure the pack commands.
For more commands, see the Setuptools official website. |
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 9 10 11 12 | version: 2.0 # The value must be 2.0. steps: BUILD: - python: name: Build with Setuptools image: cloudbuild@python3.6 inputs: command: | pip config set global.index-url https://pypi.org/simple pip config set global.trusted-host repo.xxcloud.com python setup.py bdist_egg ignore_fail: true |
| Parameter | Type | Description |
| name | String | Optional. Assign a custom name to the build action. The name can contain:
| image | String | Optional. Enter the image version, which should include the fixed part cloudbuild@ and the supported Python version following it. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. The default value is cloudbuild@python3.6. |
| command | String | Configure the pack commands.
| ignore_fail | String | Whether to proceed after the current action fails.
