Building with Gradle
Build a Java, Groovy, or Scala project with Gradle.
Build on GUI
Add Build with Gradle, when configuring build actions. Set the parameters according to Table 1.
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Gradle | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| JDK | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| Commands | Configure the Gradle commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the Gradle official website. |
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 9 10 11 12 13 | version: 2.0 # The value must be 2.0. steps: BUILD: - gradle: inputs: gradle: 4.8 jdk: 1.8 command: | # Gradle Wrapper provided by CodeArts is used for cache acceleration. cp /cache/android/wrapper/gradle-wrapper.jar ./gradle/wrapper/gradle-wrapper.jar # Build an unsigned APK. /bin/bash ./gradlew build --init-script ./.codeci/.gradle/init_template.gradle -Dorg.gradle.daemon=false -Dorg.gradle.internal.http.connectionTimeout=800000 ignore_fail: true |
| Parameter | Type | Description |
| command | String | Configure the Gradle commands. For more commands, see the Gradle official website. |
| gradle | String | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| jdk | String | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| ignore_fail | String | Specify whether to proceed after the current action fails.
Helpful Links
Hit snags in Gradle builds? See Gradle Build FAQs.
