- What's New
- Function Overview
Getting Started
- Building with Ant and Uploading the Package to a Release Repo (x86, Preset Image, GUI)
- Building with CMake and Uploading the Package to a Release Repo (Arm, Preset Image, GUI)
- Building with Maven, Uploading the Software Package, and Pushing the Image (x86, Preset Image, Code)
- Common Practices for Beginners
User Guide
- Working with CodeArts Build
- Enabling CodeArts Build
- Configuring Project-Level Role Permissions
- Creating a Build Task
Configuring a Build Task
- Performing Basic Configurations
- Selecting Build Actions
Configuring Build Actions
- Building with Android
- Building with npm
- Building with Gradle
- Building with Yarn
- Building with Gulp
- Building with Grunt
- Building with Mono
- Building in PHP
- Building with Setuptools
- Building with PyInstaller
- Running Shell Commands
- Building with GNU Arm
- Building with Ant
- Building with Kotlin
- Building with Go
- Building Android App with Ionic
- Building an Android Quick App
- Building with sbt
- Building with Grails
- Building with Bazel
- Building with Flutter
- Building with HarmonyOS
- Running Docker Commands to Operate Images
- Generating a Unit Test Report
- Customizing a Build Environment
- Using a Custom Build Environment
- Downloading a Software Package from Release Repos
- Uploading a Software Package to Release Repos
- Uploading Files to OBS
- Configuring Parameters
- Configuring Schedules
- Configuring Roles and Permissions
- Configuring Notifications
- Running a Build Task
- Viewing a Build Task
- Managing Build Tasks
- Querying Audit Logs
- References
- Old User Guide
Best Practices
- Creating a Docker Image with a Maven Artifact and Pushing the Image to SWR (Built-in Executors, GUI)
- Building with Maven and Uploading the Software Package to the Self-hosted Repo (Built-in Executors, GUI)
- Building with Maven to Generate a Private Dependency for Another Build (Built-in Executors, GUI)
- Building with npm and Uploading the Software Package to the Release Repo (Built-in Executors, GUI)
- Building with Maven (Custom Executors, GUI)
- Building with Maven, Uploading the Software Package, and Pushing the Image to SWR (Built-in Executors, Code)
- Running a Multi-Task Maven Build Project (Built-in Executors, Code)
- Using the File from the Self-hosted Repo to Build with Maven and Uploading the Resulting Software Package (Built-in Executors, GUI)
- Running a Build Task on a Custom Environment (Built-in Executors, GUI)
API Reference
- Before You Start
- API Overview
- Calling APIs
Task APIs
- Querying Build History in a Specified Period
- Downloading the Keystore File
- Viewing Task Status
- Querying Build Tasks in a Project
- Querying the Latest Successful Build with a Specified Code Repository
- Querying Details of a Build Record
- Querying Success Rate of a Build Task in a Specified Period
- Downloading All Build Logs
- Downloading Logs of Build Actions
- Obtaining Information About Build Records
- Obtaining Details About Build Results
- Stopping a Build Task
- Deleting a Build Task
- Disabling a Build Task
- Restoring a Build Task
- Updating a Build Task
- Querying a Build Template
- Creating a Build Template
- Deleting a Build Template
- Querying Notifications
- Updating Notifications
- Canceling Notifications
- Obtaining Build Task Details
- Downloading Real-time Build Logs
- Obtaining Build Records of a Task
- CodeArts Build (Unavailable Soon)
- Application Examples
- Appendix
- Change History
General
- Can I Run a Build Task with a Specific Server or Server Configuration?
- Why Are the Required Project Files Not Found During Builds?
- Files Not Found During Software Package Upload
- Why Am I Prompted that My Permissions Are Insufficient When Running a Build Task?
- Why Am I Prompted that the Build Task Does Not Exist When Calling It Through a Pipeline?
- Why Is My Task Stopped?
- How Do I Migrate Common Java Projects Created with Eclipse to the Cloud?
- Service Endpoint Did Not Exist
- Incomplete JAR Due to Parallel Build Tasks
- How Do I Resolve the Error Occurred When Pulling the Sub-module During My Build?
- How Do I Fix the Submodules Checkout Error Due to a Failure to Obtain Its Revision?
- Why Are the Submodules Not Being Pulled During My Build?
Maven Builds
- What Can I Do If License Check Fails?
- Failed to Upload a Package Using the maven deploy Command
- How Do I Deal With the Missing POM File?
- How Do I Deal With the Missing Package or Symbol?
- Using the exec-maven-plugin Extension for Maven and NPM Hybrid Builds
- How Do I Fix the Errors Related to References Among Multiple Child and Parent Projects?
- How Do I Configure and Clear the Cache for a Maven Build?
- How Do I Find the Correct Build Package Path?
- How Do I Use jib-maven-plugin to Build a Maven Project and Create an Image?
- Why Is the New Package Still Built from the Old Code Even After the Code Has Been Updated?
- Why Is My Download of Maven Components Slow?
Android Builds
- How Do I Deal With the Unstable Jcenter () Configured for a Project?
- What Should I Do If an Error Occurs During the Lint Check and the Task Stops?
- What Should I Do When Dependency com.android.tools.build:gradle:3.0.1 Cannot Be Downloaded?
- Why Am I Seeing the Error Message "Javadoc generation failed"?
- Why Am I Seeing the Error Message "Could not find method google()"?
- What Can I Do If the Gradle Version Is Too Early?
- How Do I Fix the Android APK Signing Failure?
- Using Gradle for Build
npm Builds
- Why Am I Seeing the Error Message "JavaScript heap out of memory"?
- Why Am I Seeing the Error Message "enoent ENOENT: no such file or directory"?
- Why Am I Seeing the Error Message "Module not found: Error: Can't resolve ..."?
- Why Did My Build Fail Without Displaying Any Errors?
- Why Am I Seeing the Error Message "npm cb() never called"?
- Why Am I Seeing the Error Message "gyp ERR!"? stack Error: EACCES: permission denied
- Why Am I Seeing the Error Message "eslint: error 'CLODOP' is not defined"?
- How Do I Fix the node-sass Download Failure?
- Why Am I Seeing the Error Message "error: Could Not Write Config File"?
- Why Does It Take Long to Install Dependencies and Build?
- What Should I Do When the Dependency Version Cannot Be Found?
Images
- Failed to Create an Image Using Dockerfile
- Failed to Push Images to SWR
- How Do I Resolve the Image Pull Failure During a Build Task?
- No Permission to Pull Images When SWR Public Images Are Used
- Failed to Log In to the Image Repository
- How Do I Push an Image to Other Tenants?
- Pulling Docker Hub Images Times Out or Exceeds the Max. Attempts
General
- Videos
Show all
Building with npm
Build Vue and Webpack projects with npm.
Build on GUI
Add Build with npm, when configuring build actions. Set the parameters according to Table 1.
Parameter |
Description |
Action Name |
Assign a custom name to the build action. The name can contain:
Tool Version |
Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
Commands |
Configure the npm commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the Node.js official website. |
Continue After Failure |
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 |
version: 2.0 # The value must be 2.0. steps: BUILD: - npm: image: cloudbuild@nodejs8.11.2 inputs: command: | export PATH=$PATH:~/.npm-global/bin npm config set registry https://repo.example.com/repository/npm/ npm config set disturl https://repo.example.com/nodejs npm config set sass_binary_site https://repo.example.com/node-sass/ npm config set phantomjs_cdnurl https://repo.example.com/phantomjs npm config set chromedriver_cdnurl https://repo.example.com/chromedriver npm config set operadriver_cdnurl https://repo.example.com/operadriver npm config set electron_mirror https://repo.example.com/electron/ npm config set python_mirror https://repo.example.com/python npm config set prefix '~/.npm-global' npm install --verbose npm run build ignore_fail: true |
Parameter |
Type |
Description |
image |
String |
The image address can be in either of the following formats:
command |
String |
Configure the npm commands. For more commands, see the Node.js official website. |
ignore_fail |
String |
Whether to proceed after the current action fails.
