Building an Android Quick App
Run the npm configuration command to build an Android quick app.
Build on GUI
Add Build Android Quick App, when configuring build actions. Set the parameters according to Table 1.
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Tool Version | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| Commands | Configure npm commands. For more commands, see the Node.js official website. |
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 9 10 11 12 | version: 2.0 # The value must be 2.0. steps: BUILD: - quick_app: inputs: command: |- npm config set registry http://7.223.219.40/npm/ # Load dependencies npm install --verbose # Default build npm run build ignore_fail: true |
| Parameter | Type | Description |
| command | String | Configure npm commands. For more commands, see the Node.js official website. |
| ignore_fail | String | Whether to proceed after the current action fails.
