Updated on 2026-10-16 GMT+08:00
Building with Maven
Maven's primary goal is to build Java-based projects and manage project information and dependencies.
Tutorial Video
Learn to build with Maven on the GUI in this video tutorial.
Build on GUI
Add Build with Maven, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with Maven
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Configure the Maven commands, or use the default ones. For more commands, see the Maven official website.
When working with a self-hosted repo, configure the appropriate certificate-ignore commands based on the specific Maven version.
  • Maven 3.8 or earlier:
    -Dmaven.wagon.http.ssl.insecure=true -Dmaven.wagon.http.ssl.allowall=true -Dmaven.wagon.http.ssl.ignore.validity.dates=true
  • Maven 3.9 or later:
    -Dmaven.wagon.http.ssl.insecure=true -Dmaven.wagon.http.ssl.allowall=true -Dmaven.wagon.http.ssl.ignore.validity.dates=true -Dmaven.resolver.transport=wagon
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
setting File Configuration
  • Generate setting File with Repositories: The optimal repository access mode is automatically configured based on your IP address when you access the setting.xml file provided by CodeArts.
    Your IP address may be in regions in or outside the current country. You are advised to retain the default settings.
    The setting.xml file defines the default dependency pull sequence and mirror source proxy. If you need to use a custom setting.xml file, add a custom setting.xml file and add --settings settings.xml to the end of the default packaging command. Then, you can use the added settings.xml file to build with Maven.
  • Public Repositories: By default, Huawei Mirrors is added, and Huawei SDK repositories have been configured. This configuration is used only when you need to add a public repository that is not provided by CodeArts. The procedure is as follows:
    1. Click Add.
    2. Enter the repository address, and select Release and Snapshot as required. Select either Release or Snapshot, or both.
      Release: If this option is selected, the build process attempts to download the release version dependency from the repository.
      Snapshot: If this option is selected, the build process attempts to download the snapshot version dependency from the repository.
  • Private Repositories: Self-hosted repos provided by CodeArts have been configured by default. This configuration is used only when you need to add other private repositories. The procedure is as follows:
    1. Create a Nexus repository service endpoint.
    2. Click Add, select the service endpoint created in the previous step, and select Release and Snapshot as required.
      Release and Snapshot are two types of repositories. Pay attention to their differences. If you upload a dependency to a release repository, it cannot be downloaded during a build.
      • Snapshot: For private dependency packages released for debugging, add the -SNAPSHOT suffix to the dependency version (for example, 1.0.0-SNAPSHOT). During each release, the dependency is automatically released to the snapshot repository. The version does not need to be updated each time the dependency is released. You can add the -U parameter to the build command to obtain the latest version.
      • For officially released private dependency packages, do not add the -SNAPSHOT suffix to the dependency version (for example, 1.0.0). During each release, the dependency is automatically released to the release repository. The version must be updated each time the dependency is released. Otherwise, the latest dependency package cannot be obtained during the build.
Release to Self-hosted Repos
By default, CodeArts Build uses the self-hosted repos as the download source of private dependencies. If you want to upload build artifacts to the self-hosted repos and share them as dependencies with other projects, this configuration is required. Before the configuration, create a self-hosted repo. The configuration procedure is as follows:
  • Do not configure POM: Private dependencies do not need to be released to the self-hosted repo of CodeArts Artifact.
  • Configure all POMs: Deployment configurations are added to all pom.xml files of the project. The mvn deploy command is used to upload the built dependency package to a self-hosted repo.
    In the command window, use the number sign (#) to comment out the mvn package -Dmaven.test.skip=true -U -e -X -B command, as shown in the following figure.
    Delete the number sign (#) before the #mvn deploy -Dmaven.test.skip=true -U -e -X -B command, as shown in the following figure.
The uploaded private dependency can be referenced by adding the groupId, artifactId, and version coordinates in the pom.xml file to other projects.
Unit Test
To process unit test results, set the parameters. For details, see Configuring a Unit Test.
Cache
Opt to use the cache to improve the build speed. If you set Use Dependency Cache to Yes, the downloaded dependency package is cached during each build. In this way, the dependency package does not need to be pulled repeatedly during subsequent builds, which effectively improves the build speed.
The dependency cache files of a Maven build task cannot be updated. The cache directory will be updated only when new dependencies are imported to the task.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - maven:
          image: cloudbuild@maven3.5.3-jdk8-open# The image path can be customized.
          inputs:
            settings:
              public_repos:
                - https://mirrors.example.com/maven
            cache: true # Determine whether to enable caching.
            unit_test:
              coverage: true
              ignore_errors: false
              report_path: "**/TEST*.xml"
              enable: true
              coverage_report_path: "**/site/jacoco"
            command: mvn package -Dmaven.test.failure.ignore=true -U -e -X -B
            ignore_fail: true
Table 2 Parameters in the sample code
Type
String
The image address can be in either of the following formats:
  • cloudbuild@maven3.5.3-jdk8-open: This address starts with cloudbuild and uses the at sign (@) as a separator, with the default image provided by CodeArts Build following it. For image build tool versions supported by CodeArts Build, see Build Tool Versions.
  • Use a complete SWR image path, for example, swr.example.example.com/codeci_test/demo:141d26c455abd6d7xxxxxxxxxxxxxxxxxxxx.
    For details about how to obtain the image address, see Obtaining the SWR Image Path.
settings
Map
Optional. Set this parameter if you need a custom settings.xml file.
If this parameter is not set, the setting.xml file provided by CodeArts is used by default. If you need to use a custom settings.xml file, add a custom setting.xml file and add --settings settings.xml to the end of the default packaging command mvn package -Dmaven.test.failure.ignore=true -U -e -X -B.
cache
Bool
Optional.
Specify whether to enable cache.
  • true: Enable.
  • false: Disable.
The default value is false.
command
String
Configure the Maven command. For more commands, see the Maven official website.
unit_test
Map
Optional.
Configure the unit test. For details, see Configuring a Unit Test.
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
Adding a Custom setting.xml File
The file restrictions are as follows:
  • The maximum file size is 100 KB.
  • The file type must be .xml, .key, .keystore, .jks, .crt, or .pem.
  • A maximum of 20 files can be uploaded.
You can add files in either of the following ways:
  • Build on GUI
    1. In the Commands window of the Build with Maven action, run the cat /home/build/.m2/settings.xml command. After the task is complete, the content of the settings.xml file will be displayed in the build logs.
    2. Customize a new settings.xml file according to the settings.xml file's information displayed in the build logs.
    3. Add the Download File from File Manager action before the Build with Maven action.
      Assign a custom name to the action and select a tool version. Currently, only shell4.2.46-git1.8.3-zip6.00 is supported.
    4. Click Upload. In the displayed dialog box, select the file customized in 2, add the description, confirm your acceptance of the agreements, and click Save.
      If Allow all members of the account to use this file in builds is not selected, users with the te_admin permission can still edit, download, and delete files, even if they are not the file creator.
    5. Expand the File Name drop-down list and select the uploaded setting.xml file.
  • Build with Code
    3
    4
    5
    6
    7
    steps:
      BUILD:
        - download_file:
              inputs:
                ignore_fail: true
    Table 3 Parameters in the sample code for downloading a file
    Type
    name
    String
    Name of the setting file.
    ignore_fail
    String
    • true: Yes
    • Empty: No
Other Operations
Configuring a Unit Test and Generating a Unit Test Coverage Report Using JaCoCo are optional. Configure them if needed.
  • Configuring a unit test: The Maven build action leverages unit tests to ensure that your code's core functions operate as expected. Within a Maven project, testing frameworks like JUnit are used to write and execute these tests.
  • Generating a unit test coverage report using JaCoCo: The unit test coverage report distinguishes between code that has been covered by unit tests and code that has not. It helps you check whether your tests cover all code paths and logic.
