Building in PHP
Use PHP to build within an installation and packaging environment that includes the necessary PHP code libraries for the project.
Build on GUI
Add Build in PHP, when configuring build actions. Set the parameters according to Table 1.
| Parameter | Description |
| Action Name | Assign a custom name to the build action. The name can contain:
| Tool Version | Select a tool version that matches your current development environment. For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment. |
| Commands | Configure the PHP commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the PHP official website. |
| Continue After Failure | Specify whether to proceed after the current action fails by setting the parameter to either Yes or No. |
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
1 2 3 4 5 6 7 8 9 10 11 | version: 2.0 # The value must be 2.0. steps: BUILD: - php: inputs: command: |- composer config -g secure-http false composer config -g repo.packagist composer http://mirrors.tools.huawei.com/php/ composer install tar -zcvf php-composer.tgz * ignore_fail: true |
| Parameter | Type | Description |
| command | String | Configure the PHP commands. For more commands, see the PHP official website. |
| ignore_fail | String | Whether to proceed after the current action fails.
