Updated on 2026-07-29 GMT+08:00
Building with Gulp
Build a frontend IDE with Gulp.
Build on GUI
Add Build with Gulp, when configuring build actions. Set the parameters according to Table 1.
Table 1 Parameters for building with Gulp
Action Name
Assign a custom name to the build action. The name can contain:
  • Letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), and parentheses.
  • 1 to 128 characters.
Tool Version
Select a tool version that matches your current development environment.
For tool versions supported by CodeArts Build, see build tools and versions. If the current tools and versions do not meet your requirements, you can customize a build environment.
Commands
Configure the Gulp commands, or use the default ones. If you have special build requirements, enter your custom build script in the text box. For more commands, see the Gulp official website.
Continue After Failure
Specify whether to proceed after the current action fails by setting the parameter to either Yes or No.
Build with Code
Modify the code in the BUILD block in Creating a YAML File for Your Code-based Build by referring to the following sample code:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
version: 2.0 # The value must be 2.0.
steps:
  BUILD:
    - gulp:
       inputs:
          command: |-
       	        export PATH=$PATH:~/.npm-global/bin
       	        npm config set registry http://mirrors.tools.huawei.com/npm/
       	        npm config set prefix '~/.npm-global'
       	        #If node-sass needs to be installed
       	        #npm config set sass_binary_site https://repo.huaweicloud.com/node-sass/
       	        #npm install node-sass
       	        #Load dependencies
       	        npm install -verbose
       	        gulp
          ignore_fail: true
Table 2 Parameters in the sample code
Type
command
String
Configure the Gulp commands. For more commands, see the Gulp official website.
ignore_fail
String
Specify whether to proceed after the current action fails.
  • true: Yes
  • Empty: No
